nachdem alles lief, auch mehre Reboots alles glatt ging kommt nun der MySql nicht mehr hoch.
Das zeigt nginx Fehlerlog an
Wer kann helfen ?
2013/01/08 21:50:26 [error] 2633#0: *18 FastCGI sent in stderr: "PHP message: PHP Warning: mysqli::mysqli(): [2002] No such file or directory (trying to connect via unix:///var/run/mysqld/mysqld.sock) in /usr/local/ispconfig/interface/lib/classes/db_mysql.inc.php on line 60
PHP message: PHP Warning: mysqli::mysqli(): (HY000/2002): No such file or directory in /usr/local/ispconfig/interface/lib/classes/db_mysql.inc.php on line 60
PHP message: PHP Warning: mysqli::ping(): Couldn't fetch db in /usr/local/ispconfig/interface/lib/classes/db_mysql.inc.php on line 99
PHP message: PHP Warning: mysqli::query(): Couldn't fetch db in /usr/local/ispconfig/interface/lib/classes/db_mysql.inc.php on line 100
PHP message: PHP Warning: mysqli::close(): Couldn't fetch db in /usr/local/ispconfig/interface/lib/classes/db_mysql.inc.php on line 71
PHP message: PHP Warning: mysqli::close(): Couldn't fetch db in /usr/local/ispconfig/interface/lib/classes/db_mysql.inc.php on line 71" while reading response header from upstream, client: xxxxx, server: _, request: "GET /js/scrigo.js.php HTTP/1.1", upstream: "fastcgi://unix:/var/lib/php5-fpm/ispconfig.sock:", host: "xxxxx:8080", referrer: "https://xxxxx:8080/index.php"
