vor wenigen Tagen ist ein Server im RZ aus unerklärlichen Gründen abgestürzt. Laut Logs war das ein Problem mit dem Festplatten-Cache. Ich habe der Sache keine Bedeutung beigemessen, bis dies gestern in der Nacht wieder passiert ist. "smartctl -a /dev/sda" gab folgendes aus:
Was könnte dies sein? Rein vorsorglich habe ich die HDD ausgetauscht. Mit "badblocks -s /dev/sda" gab es keine Fehler. Folglich habe ich die Platte sektorenweise kopiert.
Viele Grüße
Hahni
smartctl version 5.37 [i686-pc-linux-gnu] Copyright (C) 2002-6 Bruce Allen Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model: WDC WD2502ABYS-02B7A0
Serial Number: WD-WCAT1F653717
Firmware Version: 02.03B03
User Capacity: 251.059.544.064 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Sun Jan 29 05:07:51 2012 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (4800) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 59) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 200 198 021 Pre-fail Always - 966
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 17
5 Reallocated_Sector_Ct 0x0033 185 185 140 Pre-fail Always - 116
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 091 091 000 Old_age Always - 6994
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 13
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 3
194 Temperature_Celsius 0x0022 112 109 000 Old_age Always - 31
196 Reallocated_Event_Count 0x0032 187 187 000 Old_age Always - 13
197 Current_Pending_Sector 0x0032 199 199 000 Old_age Always - 42
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 2
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
Warning: ATA error count 448 inconsistent with error log pointer 1
ATA Error Count: 448 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 448 occurred at disk power-on lifetime: 6990 hours (291 days + 6 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 41 00 f7 04 2c e0 Error: ABRT at LBA = 0x002c04f7 = 2884855
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 08 f7 04 2c 00 0a 10d+10:11:56.570 READ DMA
ec 00 00 00 00 00 00 0a 10d+10:11:56.549 IDENTIFY DEVICE
ef 03 42 00 00 00 00 0a 10d+10:11:56.533 SET FEATURES [Set transfer mode]
Error 447 occurred at disk power-on lifetime: 6990 hours (291 days + 6 hours)
c8 00 08 f7 04 2c 00 0a 10d+10:11:52.574 READ DMA
ec 00 00 00 00 00 00 0a 10d+10:11:52.553 IDENTIFY DEVICE
ef 03 42 00 00 00 00 0a 10d+10:11:52.536 SET FEATURES [Set transfer mode]
Error 446 occurred at disk power-on lifetime: 6990 hours (291 days + 6 hours)
c8 00 08 f7 04 2c 00 0a 10d+10:11:48.729 READ DMA
ec 00 00 00 00 00 00 0a 10d+10:11:48.697 IDENTIFY DEVICE
ef 03 42 00 00 00 00 0a 10d+10:11:48.678 SET FEATURES [Set transfer mode]
Error 445 occurred at disk power-on lifetime: 6990 hours (291 days + 6 hours)
c8 00 08 f7 04 2c 00 0a 10d+10:11:44.720 READ DMA
ec 00 00 00 00 00 00 0a 10d+10:11:44.699 IDENTIFY DEVICE
ef 03 42 00 00 00 00 0a 10d+10:11:44.680 SET FEATURES [Set transfer mode]
Error 444 occurred at disk power-on lifetime: 6990 hours (291 days + 6 hours)
c8 00 08 f7 04 2c 00 0a 10d+10:11:40.704 READ DMA
ec 00 00 00 00 00 00 0a 10d+10:11:40.684 IDENTIFY DEVICE
ef 03 42 00 00 00 00 0a 10d+10:11:40.684 SET FEATURES [Set transfer mode]
SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Viele Grüße
Hahni
