Fehler fehler und noch mehr Fehler
Esolein
Ich bin mir nicht sicher wie die entstehen
aber ich möchte diese gerne beheben.
An unexpected database error occurred. Please try again later.
Wenn man eine seite aufrufet.
Das befindet sich in debug:
root@h2918657:/usr/local/ispconfig/server# ./server.sh
Cannot load the ionCube PHP Loader - it was already loaded
16.02.2021-01:46 - DEBUG - Unable to register function 'process' from plugin 'so ftware_update_plugin' for event 'software_update_inst_insert'
16.02.2021-01:46 - DEBUG - Calling function 'check_phpini_changes' from plugin ' webserver_plugin' raised by action 'server_plugins_loaded'.
16.02.2021-01:46 - DEBUG - Found 2 changes, starting update process.
16.02.2021-01:46 - DEBUG - Calling function 'server_ip' from plugin 'apache2_plu gin' raised by event 'server_update'.
16.02.2021-01:46 - DEBUG - safe_exec cmd: which 'apache2ctl' 2> /dev/null - retu rn code: 0
16.02.2021-01:46 - DEBUG - Writing the conf file: /etc/apache2/sites-available/i spconfig.conf
16.02.2021-01:46 - DEBUG - Calling function 'update' from plugin 'apps_vhost_plu gin' raised by event 'server_update'.
16.02.2021-01:46 - DEBUG - Calling function 'update' from plugin 'network_settin gs_plugin' raised by event 'server_update'.
16.02.2021-01:46 - DEBUG - Calling function 'update' from plugin 'postfix_server _plugin' raised by event 'server_update'.
postconf: fatal: file /etc/postfix/master.cf: line 21: bad field count
16.02.2021-01:46 - DEBUG - safe_exec cmd: postconf -e 'smtpd_client_restrictions = ' - return code: 0
16.02.2021-01:46 - DEBUG - safe_exec cmd: postconf -e 'smtpd_helo_restrictions = reject_unknown_helo_hostname' - return code: 0
16.02.2021-01:46 - DEBUG - safe_exec cmd: which 'dovecot' 2> /dev/null - return code: 0
/usr/sbin/postconf: fatal: file /etc/postfix/master.cf: line 21: bad field count
postfix/postfix-script: fatal: cannot execute /usr/sbin/postconf!
16.02.2021-01:46 - DEBUG - Calling function 'update' from plugin 'server_service s_plugin' raised by event 'server_update'.
16.02.2021-01:46 - DEBUG - Calling function 'server_update' from plugin 'webserv er_plugin' raised by event 'server_update'.
16.02.2021-01:46 - DEBUG - Calling function 'update' from plugin 'xmpp_plugin' r aised by event 'server_update'.
16.02.2021-01:46 - DEBUG - Processed datalog_id 6011
16.02.2021-01:47 - DEBUG - Calling function 'update' from plugin 'server_service s_plugin' raised by event 'server_update'.
16.02.2021-01:47 - DEBUG - Calling function 'server_update' from plugin 'webserv er_plugin' raised by event 'server_update'.
matz
Hast du schon (im Fall von postfix) in der entsprechenden Zeile genannten Konfig-Datei nachgeschaut? Z.B. master.cf: line 21? Es kann sein, dass dort die Spaces nicht passen. Alle Fehler die in deiner Auflistung auftauchen kann man in die Suchmaschine seines Vertrauens eingeben und bekommt oft brauchbare Lösungsansätze.
