Ich nutze 3.0.2.1 auf opensuse 11.2. sind den logs sind einige Probleme drin. SASL Login scheitert und mit clamav stimmt irgendetwas nicht.
Maiprotokoll:
Jun 20 12:25:20 srv01 pop3d: LOGIN, user=info@webcoreserver.de, ip=[::ffff:84.57.124.25], port=[49823]
Jun 20 12:25:20 srv01 pop3d: LOGOUT, user=info@webcoreserver.de, ip=[::ffff:84.57.124.25], port=[49823], top=0, retr=0, rcvd=12, sent=39, time=0
Jun 20 12:25:21 srv01 postfix/smtpd[1458]: connect from dslb-084-057-124-025.pools.arcor-ip.net[84.57.124.25]
Jun 20 12:25:21 srv01 postfix/smtpd[1458]: warning: dslb-084-057-124-025.pools.arcor-ip.net[84.57.124.25]: SASL LOGIN authentication failed: authentication failure
Jun 20 12:25:25 srv01 postfix/smtpd[1458]: lost connection after AUTH from dslb-084-057-124-025.pools.arcor-ip.net[84.57.124.25]
Jun 20 12:25:25 srv01 postfix/smtpd[1458]: disconnect from dslb-084-057-124-025.pools.arcor-ip.net[84.57.124.25]
Mailwarn:
Jun 20 12:19:16 srv01 amavis[28498]: (28498-01) (!)ClamAV-clamd: Can't connect to UNIX socket /var/run/clamav/clamd: No such file or directory, retrying (2)
Jun 20 12:19:22 srv01 amavis[28498]: (28498-01) (!!)ClamAV-clamd av-scanner FAILED: run_av error: Too many retries to talk to /var/run/clamav/clamd (Can't connect to UNIX socket /var/run/clamav/clamd: No such file or directory) at (eval 101) line 325.
Jun 20 12:19:22 srv01 amavis[28498]: (28498-01) (!!)WARN: all primary virus scanners failed, considering backups
Mailerror:
Da habert es wohl noch an der Konfiguration oder?
