[B]Mail - Protokoll (Server : lawi.xxxxxxxxxx.de)[/B]
Nov 27 05:02:39 lawi dovecot: pop3-login: Login: user=, method=PLAIN, rip=xx.1xx.x.xx3, lip=x9.xxx.xxx.x7
Nov 27 05:02:39 lawi dovecot: POP3(info@xxxxxxxxxx.de): Disconnected: Logged out top=0/0, retr=0/0, del=0/0, size=0
Nov 27 05:03:05 lawi postfix/smtpd[13614]: connect from xxxx-xxxxxx7.pool.xxxxxWxxx.xxx[7x.xxx.x.xx3]
Nov 27 05:03:06 lawi postfix/smtpd[13614]: 2E05C5BA08B: client=xxxx-xxxxxx7.pool.xxxxxWxxx.xxx[7x.xxx.x.xx3], sasl_method=LOGIN, sasl_username=info@xxxxxxxxxx.de
Nov 27 05:03:06 lawi postfix/cleanup[13618]: 2E05C5BA08B: message-id=<xxxxxxxx.xxxxxx.xxxxx@Mein-PC>
Nov 27 05:03:07 lawi postfix/qmgr[18125]: 2E05C5BA08B: from=, size=144822, nrcpt=1 (queue active)
Nov 27 05:03:07 lawi postfix/smtpd[13614]: disconnect from xxxx-xxxxxx7.pool.xxxxxWxxx.xxx[7x.xxx.x.xx3]
Nov 27 05:03:08 lawi amavis[16713]: (16713-05) NOTICE: reconnecting in response to: err=2006, HY000, DBD::mysql::st execute failed: MySQL server has gone away at (eval 103) line 166, line 5.
Nov 27 05:03:09 lawi postfix/smtpd[13622]: connect from localhost[127.0.0.1]
Nov 27 05:03:09 lawi postfix/smtpd[13622]: 4294B5BA08C: client=localhost[127.0.0.1]
Nov 27 05:03:09 lawi postfix/cleanup[13618]: 4294B5BA08C: message-id=<xxxxxxxx.xxxxxx.xxxxx@Mein-PC>
Nov 27 05:03:09 lawi postfix/qmgr[18125]: 4294B5BA08C: from=, size=145409, nrcpt=1 (queue active)
Nov 27 05:03:09 lawi postfix/smtpd[13622]: disconnect from localhost[127.0.0.1]
Nov 27 05:03:09 lawi amavis[16713]: (16713-05) Passed BAD-HEADER, [xx.1xx.x.xx3] [xx.1xx.x.xx3] -> , quarantine: 1/badh-1Y1A9ZYgyOhV, Message-ID: <xxxxxxxx.xxxxxx.xxxxx@Mein-PC>, mail_id: 1Y1A9ZYgyOhV, Hits: 0.809, size: 144822, queued_as: 4294B5BA08C, 1614 ms
Nov 27 05:03:09 lawi postfix/smtp[13619]: 2E05C5BA08B: to=, relay=127.0.0.1[127.0.0.1]:10024, delay=3.4, delays=1.8/0.01/0.25/1.4, dsn=2.0.0, status=sent (250 2.0.0 Ok, id=16713-05, from MTA([127.0.0.1]:10025): 250 2.0.0 Ok: queued as 4294B5BA08C)
Nov 27 05:03:09 lawi postfix/qmgr[18125]: 2E05C5BA08B: removed
Nov 27 05:03:10 lawi postfix/smtp[13623]: 4294B5BA08C: to=, relay=mx0.gmx.net[213.165.64.100]:25, delay=0.88, delays=0.05/0.01/0.06/0.75, dsn=2.6.0, status=sent (250 2.6.0 Message accepted {mx020})
Nov 27 05:03:10 lawi postfix/qmgr[18125]: 4294B5BA08C: removed
Nov 27 05:03:11 lawi dovecot: pop3-login: Login: user=, method=PLAIN, rip=xx.1xx.x.xx3, lip=x9.xxx.xxx.x7
Nov 27 05:03:11 lawi dovecot: POP3(info@xxxxxxxxxx.de): Disconnected: Logged out top=0/0, retr=0/0, del=0/0, size=0
Nov 27 05:03:22 lawi dovecot: pop3-login: Login: user=, method=PLAIN, rip=xx.1xx.x.xx3, lip=x9.xxx.xxx.x7
Nov 27 05:03:22 lawi dovecot: POP3(info@xxxxxxxxxx.de): Disconnected: Logged out top=0/0, retr=0/0, del=0/0, size=0
Nov 27 05:05:01 lawi dovecot: pop3-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Nov 27 05:05:01 lawi dovecot: imap-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
