kuschelstunde
wenn ich "drbdadm create-md cluster_metadata" absetze, erhalte ich einen Fehler.
Woran liegt es?
Hier meine DRBD.conf
global {
usage-count ask;
common {
syncer { rate 100M; }
resource cluster_metadata {
protocol C;
handlers {
pri-on-incon-degr "echo O > /proc/sysrq-trigger ; halt -f";
pri-lost-after-sb "echo O > /proc/sysrq-trigger ; halt -f";
local-io-error "echo O > /proc/sysrq-trigger ; halt -f";
startup {
degr-wfc-timeout 120; # 2 minutes.
disk {
on-io-error detach;
net {
after-sb-0pri disconnect;
after-sb-1pri disconnect;
after-sb-2pri disconnect;
rr-conflict disconnect;
syncer {
# rate 10M;
# after "r2";
al-extents 257;
on filer1 {
device /dev/drbd0;
disk /dev/sda3;
address 10.10.1.1:7788;
meta-disk internal;
on filer2 {
device /dev/drbd0;
disk /dev/sda3;
address 10.10.1.2:7788;
meta-disk internal;
resource vg0drbd {
protocol C;
startup {
wfc-timeout 0; ## Infinite!
degr-wfc-timeout 120; ## 2 minutes.
disk {
on-io-error detach;
net {
# timeout 60;
# connect-int 10;
# ping-int 10;
# max-buffers 2048;
# max-epoch-size 2048;
syncer {
after "cluster_metadata";
on filer1 {
device /dev/drbd1;
disk /dev/sda5;
address 10.10.1.1:7789; #nochaendern
meta-disk internal;
on filer2 {
device /dev/drbd1;
disk /dev/sda5;
address 10.10.1.2:7789; #nochaendern
meta-disk internal;
resource vg1drbd {
protocol C;
startup {
disk {
on-io-error detach;
net {
# timeout 60;
# connect-int 10;
# ping-int 10;
# max-buffers 2048;
syncer {
on filer1 {
device /dev/drbd2;
disk /dev/sdb1;
meta-disk internal;
on filer2 {
device /dev/drbd2;
disk /dev/sdb1;
meta-disk internal;
Bin für jede Hilfe sehr dankbar![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Woran liegt es?
global {
usage-count ask;
common {
protocol C;
handlers {
startup {
disk {
on-io-error detach;
net {
syncer {
# rate 10M;
# after "r2";
al-extents 257;
on filer1 {
device /dev/drbd0;
disk /dev/sda3;
meta-disk internal;
on filer2 {
device /dev/drbd0;
disk /dev/sda3;
meta-disk internal;
resource vg0drbd {
protocol C;
startup {
disk {
on-io-error detach;
net {
# timeout 60;
# connect-int 10;
# ping-int 10;
# max-buffers 2048;
syncer {
on filer1 {
device /dev/drbd1;
disk /dev/sda5;
meta-disk internal;
on filer2 {
device /dev/drbd1;
disk /dev/sda5;
meta-disk internal;
resource vg1drbd {
protocol C;
startup {
disk {
on-io-error detach;
net {
# timeout 60;
# connect-int 10;
# ping-int 10;
# max-buffers 2048;
syncer {
on filer1 {
device /dev/drbd2;
disk /dev/sdb1;
meta-disk internal;
on filer2 {
device /dev/drbd2;
disk /dev/sdb1;
meta-disk internal;
