unter dem Punkt installierte Pakete erhalte ich statt einer Liste folgende Ausgabe:
ISPConfig Version 3.0.5.1
Könnte das ein Bug sein?
DB::query(SELECT aps_instances.id AS id, aps_instances.package_id AS package_id, aps_instances.customer_id AS customer_id, sys_group.name AS customer_name, aps_instances.instance_status AS instance_status, aps_packages.name AS package_name, aps_packages.version AS package_version, aps_packages.release AS package_release, aps_packages.package_status AS package_status, CONCAT ((SELECT value FROM aps_instances_settings WHERE name='main_domain' AND instance_id = aps_instances.id), '/', (SELECT value FROM aps_instances_settings WHERE name='main_location' AND instance_id = aps_instances.id)) AS install_location FROM aps_instances, aps_packages, sys_group WHERE sys_group.client_id = aps_instances.customer_id AND aps_instances.package_id = aps_packages.id ORDER BY package_name LIMIT 0, 15) -> mysqli_query FUNCTION dbispconfig.CONCAT does not exist#0 db->query(SELECT aps_instances.id AS id, aps_instances.package_id AS package_id, aps_instances.customer_id AS customer_id, sys_group.name AS customer_name, aps_instances.instance_status AS instance_status, aps_packages.name AS package_name, aps_packages.version AS package_version, aps_packages.release AS package_release, aps_packages.package_status AS package_status, CONCAT ((SELECT value FROM aps_instances_settings WHERE name='main_domain' AND instance_id = aps_instances.id), '/', (SELECT value FROM aps_instances_settings WHERE name='main_location' AND instance_id = aps_instances.id)) AS install_location FROM aps_instances, aps_packages, sys_group WHERE sys_group.client_id = aps_instances.customer_id AND aps_instances.package_id = aps_packages.id ORDER BY package_name LIMIT 0, 15) called at [/usr/local/ispconfig/interface/lib/classes/db_mysql.inc.php:157] #1 db->queryAllRecords(SELECT aps_instances.id AS id, aps_instances.package_id AS package_id, aps_instances.customer_id AS customer_id, sys_group.name AS customer_name, aps_instances.instance_status AS instance_status, aps_packages.name AS package_name, aps_packages.version AS package_version, aps_packages.release AS package_release, aps_packages.package_status AS package_status, CONCAT ((SELECT value FROM aps_instances_settings WHERE name='main_domain' AND instance_id = aps_instances.id), '/', (SELECT value FROM aps_instances_settings WHERE name='main_location' AND instance_id = aps_instances.id)) AS install_location FROM aps_instances, aps_packages, sys_group WHERE sys_group.client_id = aps_instances.customer_id AND aps_instances.package_id = aps_packages.id ORDER BY package_name LIMIT 0, 15) called at [/usr/local/ispconfig/interface/web/sites/aps_installedpackages_list.php:112]
