nachdem ich das letsencrypt - Zertifikat unter ISPConfig 3.1 für eine Domain aktivieren wollte, stürzte der apache ab.
root@server-01:/usr/src# apache2ctl configtest && apache2ctl start
AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/apache2/sites-enabled/000-ispconfig.conf:69
Syntax OK
Action 'start' failed.
The Apache error log may have more information.
000-ispconfig.conf
Alias /.well-known/acme-challenge /usr/local/ispconfig/interface/acme/.well-known/acme-challenge
<Directory /usr/local/ispconfig/interface/acme/.well-known/acme-challenge>
Require all granted
</Directory>
NameVirtualHost *:80 -> Zeile 69
NameVirtualHost *:443
NameVirtualHost IP:80
NameVirtualHost IP:443
error.log
[Sat Oct 22 16:16:02.004308 2016] [ssl:error] [pid 3667] AH02567: Unable to configure certificate server:8080:0 for stapling
[ 2016-10-22 16:16:02.0133 4400/7f9f14e5f740 agents/Watchdog/Main.cpp:538 ]: Options: { 'analytics_log_user' => 'nobody', 'default_group' => 'nogroup', 'default_python' => 'python', 'default_ruby' => '/usr/bin/ruby', 'default_user' => 'nobody', 'log_level' => '0', 'max_pool_size' => '6', 'passenger_root' => '/usr/lib/ruby/vendor_ruby/phusion_passenger/locations.ini', 'passenger_version' => '4.0.53', 'pool_idle_time' => '300', 'temp_dir' => '/tmp', 'union_station_gateway_address' => 'gateway.unionstationapp.com', 'union_station_gateway_port' => '443', 'user_switching' => 'true', 'web_server_passenger_version' => '4.0.53', 'web_server_pid' => '3667', 'web_server_type' => 'apache', 'web_server_worker_gid' => '33', 'web_server_worker_uid' => '33' }
[ 2016-10-22 16:16:02.0199 4403/7f84580b1740 agents/HelperAgent/Main.cpp:650 ]: PassengerHelperAgent online, listening at unix:/tmp/passenger.1.0.3667/generation-1/request
[ 2016-10-22 16:16:02.0362 4411/7f4d2aa1d780 agents/LoggingAgent/Main.cpp:321 ]: PassengerLoggingAgent online, listening at unix:/tmp/passenger.1.0.3667/generation-1/logging
[ 2016-10-22 16:16:02.0365 4400/7f9f14e5f740 agents/Watchdog/Main.cpp:728 ]: All Phusion Passenger agents started!
[Sat Oct 22 16:16:02.079061 2016] [:error] [pid 3667] python_init: Python version mismatch, expected '2.7.5+', found '2.7.9'.
[Sat Oct 22 16:16:02.079194 2016] [:error] [pid 3667] python_init: Python executable found '/usr/bin/python'.
[Sat Oct 22 16:16:02.079202 2016] [:error] [pid 3667] python_init: Python path being used '/usr/lib/python2.7/:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload'.
[Sat Oct 22 16:16:02.079218 2016] [:notice] [pid 3667] mod_python: Creating 8 session mutexes based on 150 max processes and 0 max threads.
[Sat Oct 22 16:16:02.079228 2016] [:notice] [pid 3667] mod_python: using mutex_directory /tmp
[Sat Oct 22 16:16:02.089699 2016] [mpm_prefork:notice] [pid 3667] AH00163: Apache/2.4.10 (Debian) mod_fastcgi/mod_fastcgi-SNAP-0910052141 OpenSSL/1.0.1t mod_fcgid/2.3.9 Phusion_Passenger/4.0.53 mod_python/3.3.1 Python/2.7.9 configured -- resuming normal operations
[Sat Oct 22 16:16:02.089726 2016] [core:notice] [pid 3667] AH00094: Command line: '/usr/sbin/apache2'
[Sat Oct 22 16:16:02.089763 2016] [mpm_prefork:warn] [pid 3667] AH00167: long lost child came home! (pid 3670)
[Sat Oct 22 16:18:02.710177 2016] [mpm_prefork:notice] [pid 3667] AH00169: caught SIGTERM, shutting down
AH00016: Configuration Failed
Über einen Tipp würde ich mich sehr freuen.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Danke und Grüße,
Sven
Syntax OK
000-ispconfig.conf
Require all granted
</Directory>
error.log
Danke und Grüße,
Sven
