postfix sendet keine mails
ubuman
hallo,
habe nach diesem howto (HowtoForge Linux Tutorials » Der Perfekte Server - Ubuntu 12.04 LTS (Apache2, BIND, Dovecot, ISPConfig 3)) meinen server eingerichtet.. alles schön und gut.. konnte bisher aber seit mehreren tagen keine einzige mail senden :confused::confused:
main.cf
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
# TLS parameters
smtpd_tls_cert_file = /etc/ssl/certs/ssl-snakeoil.pem
smtpd_tls_key_file = /etc/ssl/private/ssl-snakeoil.key
smtpd_use_tls = yes
myhostname = meinedomain.de
mydomain = meinedomain.de
alias_maps = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
alias_database = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
mydestination = localhost, localhost.localdomain
relayhost =
mailbox_size_limit = 0
recipient_delimiter =
inet_interfaces = all
virtual_alias_domains =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, proxy:mysql:/etc/postfix/mysql-virtual_email2email.cf, hash:/var/lib/mailman/data/virtual-mailman
inet_protocols = all
smtpd_sasl_auth_enable = yes
smtpd_recipient_restrictions = reject_unknown_sender_domain, reject_unknown_recipient_domain, reject_unauth_pipelining, permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination
transport_maps = hash:/var/lib/mailman/data/transport-mailman, proxy:mysql:/etc/postfix/mysql-virtual_transports.cf
smtpd_sender_restrictions = reject_unknown_sender_domain
smtpd_client_message_rate_limit = 100
virtual_transport = dovecot
owner_request_special = no
smtpd_sasl_type = dovecot
smtpd_sasl_path = smtpd
message_size_limit = 0
home_mailbox = Maildir/
smtpd_sasl_local_domain = $myhostname
mailbox_command = /usr/lib/dovecot/deliver -c /etc/dovecot/conf.d/01-mail-stack-delivery.conf -m "${EXTENSION}"
smtp_use_tls = yes
smtpd_tls_mandatory_protocols = SSLv3, TLSv1
smtpd_tls_mandatory_ciphers = medium
smtpd_tls_auth_only = yes
# a bit more spam protection
disable_vrfy_command = yes
# Virtual mailbox settings
virtual_mailbox_domains = mysql:/etc/postfix/mysql-virtual_domains.cf
proxy:mysql:$config_directory/mysql_virtual_mailbox_maps.cf,
proxy:mysql:$config_directory/mysql_virtual_alias_domain_mailbox_maps.cf,
proxy:mysql:$config_directory/mysql_virtual_alias_domain_catchall_maps.cf
proxy:mysql:$config_directory/mysql_virtual_alias_maps.cf,
proxy:mysql:$config_directory/mysql_virtual_alias_domain_maps.cf
virtual_mailbox_limit = proxy:mysql:$config_directory/mysql_virtual_mailbox_limit_maps.cf
virtual_minimum_uid = 150
virtual_uid_maps = static:150
virtual_gid_maps = static:8
# SASL Authentication
smtpd_sasl_exceptions_networks = $mynetworks
# No open relay!
permit_mynetworks
permit
smtp_generic_maps = hash:/etc/postfix/generic
ubuman
master.cf
# Postfix master process configuration file. For details on the format
# of the file, see the master(5) manual page (command: "man 5 master").
# Do not forget to execute "postfix reload" after editing this file.
# service type private unpriv chroot wakeup maxproc command + args
# (yes) (yes) (yes) (never) (100)
smtp inet n - - - - smtpd
#smtp inet n - - - 1 postscreen
#smtpd pass - - - - - smtpd
#dnsblog unix - - - - 0 dnsblog
#tlsproxy unix - - - - 0 tlsproxy
#submission inet n - - - - smtpd
# -o syslog_name=postfix/submission
# -o smtpd_tls_security_level=encrypt
# -o smtpd_sasl_auth_enable=yes
# -o smtpd_client_restrictions=permit_sasl_authenticated,reject
# -o milter_macro_daemon_name=ORIGINATING
smtps inet n - - - - smtpd
# -o syslog_name=postfix/smtps
-o smtpd_tls_wrappermode=yes
#628 inet n - - - - qmqpd
pickup fifo n - - 60 1 pickup
cleanup unix n - - - 0 cleanup
qmgr fifo n - n 300 1 qmgr
#qmgr fifo n - n 300 1 oqmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - - - - smtp
relay unix - - - - - smtp
# -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - - - - showq
error unix - - - - - error
retry unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# Many of the following services use the Postfix pipe(8) delivery
# agent. See the pipe(8) man page for information about ${recipient}
# and other message envelope options.
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/bin/maildrop -d vmail ${extension} ${recipient} ${user} ${nexthop} ${sender}
# Recent Cyrus versions can use the existing "lmtp" master.cf entry.
# Specify in cyrus.conf:
# lmtp cmd="lmtpd -a" listen="localhost:lmtp" proto=tcp4
# Specify in main.cf one or more of the following:
# mailbox_transport = lmtp:inet:localhost
# virtual_transport = lmtp:inet:localhost
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
# user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
# Old example of delivery via Cyrus.
#old-cyrus unix - n n - - pipe
# flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
# See the Postfix UUCP_README file for configuration details.
uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman unix - n n - - pipe
flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
${nexthop} ${user}
dovecot unix - n n - - pipe
flags=DRhu user=vmail:vmail argv=/usr/lib/dovecot/deliver -f ${sender} -d ${recipient}
amavis unix - - - - 2 smtp
-o smtp_data_done_timeout=1200
-o smtp_send_xforward_command=yes
127.0.0.1:10025 inet n - - - - smtpd
-o content_filter=
-o local_recipient_maps=
-o relay_recipient_maps=
-o smtpd_restriction_classes=
-o smtpd_helo_restrictions=
-o smtpd_sender_restrictions=
-o smtpd_recipient_restrictions=permit_mynetworks,reject
-o mynetworks=127.0.0.0/8
-o strict_rfc821_envelopes=yes
-o receive_override_options=no_unknown_recipient_checks,no_header_body_checks
das sind die daten.. wie oben auch beschrieben habe ich das howto genommen welches ispconfig mit squirrelmail einrichtet.. aber ich krieg keine mails raus weder rein.. ich werde langsam echt verrückt :( :)
ubuman
dies wäre ein abschintt aus mail.log
Mar 4 21:37:22 Ubuntu-1204-precise-64-minimal postfix/trivial-rewrite[3482]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
Mar 4 21:37:22 Ubuntu-1204-precise-64-minimal postfix/trivial-rewrite[3482]: warning: mysql:/etc/postfix/mysql-virtual_domains.cf: table lookup problem
Mar 4 21:37:22 Ubuntu-1204-precise-64-minimal postfix/trivial-rewrite[3482]: warning: virtual_mailbox_domains lookup failure
Mar 4 21:37:23 Ubuntu-1204-precise-64-minimal postfix/trivial-rewrite[3482]: warning: mysql:/etc/postfix/mysql-virtual_domains.cf: table lookup problem
Mar 4 21:37:23 Ubuntu-1204-precise-64-minimal postfix/trivial-rewrite[3482]: warning: virtual_mailbox_domains lookup failure
Mar 4 21:37:23 Ubuntu-1204-precise-64-minimal postfix/smtpd[3383]: NOQUEUE: reject: RCPT from unknown[37.45.190.130]: 451 4.3.0 <sbesgrove@bassmute.com>: Temporary lookup failure; from=<sbesgrove@bassmute.com> to=<nichols@oletuarte.com> proto=SMTP helo=<37.212.201.70>
Mar 4 21:37:24 Ubuntu-1204-precise-64-minimal postfix/smtpd[3383]: lost connection after RCPT from unknown[37.45.190.130]
Mar 4 21:37:24 Ubuntu-1204-precise-64-minimal postfix/smtpd[3383]: disconnect from unknown[37.45.190.130]
Mar 4 21:37:59 Ubuntu-1204-precise-64-minimal postfix/smtpd[3383]: connect from debian6a.polnetwork.com[91.142.211.86]
Mar 4 21:38:00 Ubuntu-1204-precise-64-minimal postfix/trivial-rewrite[3482]: warning: mysql:/etc/postfix/mysql-virtual_domains.cf: table lookup problem
Mar 4 21:38:00 Ubuntu-1204-precise-64-minimal postfix/trivial-rewrite[3482]: warning: virtual_mailbox_domains lookup failure
Mar 4 21:38:00 Ubuntu-1204-precise-64-minimal postfix/smtpd[3383]: NOQUEUE: reject: RCPT from debian6a.polnetwork.com[91.142.211.86]: 451 4.3.0 <newsletter-bounces@gravat.com>: Temporary lookup failure; from=<newsletter-bounces@gravat.com> to=<toti@oletuarte.com> proto=ESMTP helo=<debian6.polnetwork.com>
Mar 4 21:38:00 Ubuntu-1204-precise-64-minimal postfix/proxymap[3499]: error: open /etc/postfix/mysql_virtual_alias_maps.cf: No such file or directory
Mar 4 21:38:00 Ubuntu-1204-precise-64-minimal postfix/proxymap[3499]: error: open /etc/postfix/mysql_virtual_alias_domain_maps.cf: No such file or directory
Mar 4 21:38:00 Ubuntu-1204-precise-64-minimal postfix/proxymap[3499]: warning: mysql:/etc/postfix/mysql_virtual_alias_maps.cf is unavailable. open /etc/postfix/mysql_virtual_alias_maps.cf: No such file or directory
Mar 4 21:38:00 Ubuntu-1204-precise-64-minimal postfix/cleanup[3498]: warning: proxy:mysql:/etc/postfix/mysql_virtual_alias_maps.cf lookup error for "postmaster@meinedomain.de"
Mar 4 21:38:00 Ubuntu-1204-precise-64-minimal postfix/cleanup[3498]: warning: 2967217420C: virtual_alias_maps map lookup problem for postmaster@meinedomain.de -- deferring delivery
Mar 4 21:38:00 Ubuntu-1204-precise-64-minimal postfix/smtpd[3383]: disconnect from debian6a.polnetwork.com[91.142.211.86]
Mar 4 21:38:03 Ubuntu-1204-precise-64-minimal postfix/smtpd[3383]: connect from mail25.wdc01.mcdlv.net[205.201.129.25]
Mar 4 21:38:03 Ubuntu-1204-precise-64-minimal postfix/trivial-rewrite[3482]: warning: mysql:/etc/postfix/mysql-virtual_domains.cf: table lookup problem
Mar 4 21:38:03 Ubuntu-1204-precise-64-minimal postfix/trivial-rewrite[3482]: warning: virtual_mailbox_domains lookup failure
Mar 4 21:38:03 Ubuntu-1204-precise-64-minimal postfix/smtpd[3383]: NOQUEUE: reject: RCPT from mail25.wdc01.mcdlv.net[205.201.129.25]: 451 4.3.0 <bounce-mc.us5_12471203.286665-toti=oletuarte.com@mail25.wdc01.mcdlv.net>: Temporary lookup failure; from=<bounce-mc.us5_12471203.286665-toti=oletuarte.com@mail25.wdc01.mcdlv.net> to=<toti@oletuarte.com> proto=ESMTP helo=<mail25.wdc01.mcdlv.net>
Mar 4 21:38:03 Ubuntu-1204-precise-64-minimal postfix/smtpd[3383]: disconnect from mail25.wdc01.mcdlv.net[205.201.129.25]
ubuman
das hat wohl auch nicht geholfen :confused: nun bekomme ich diese logs..
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal postfix/smtpd[4338]: connect from localhost[127.0.0.1]
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal postfix/trivial-rewrite[3835]: warning: connect to mysql server localhost: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal postfix/trivial-rewrite[3835]: warning: mysql:/etc/postfix/mysql-virtual_domains.cf: table lookup problem
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal postfix/trivial-rewrite[3835]: warning: virtual_mailbox_domains lookup failure
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal postfix/smtpd[4338]: D64AA17420C: client=localhost[127.0.0.1]
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal postfix/proxymap[3889]: warning: mysql:/etc/postfix/mysql_virtual_alias_maps.cf is unavailable. open /etc/postfix/mysql_virtual_alias_maps.cf: No such file or directory
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal postfix/cleanup[4334]: warning: proxy:mysql:/etc/postfix/mysql_virtual_alias_maps.cf lookup error for "ziel@mail.de"
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal postfix/cleanup[4334]: warning: D64AA17420C: virtual_alias_maps map lookup problem for ziel@mail.de -- deferring delivery
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal amavis[1430]: (01430-11) Negative SMTP response to data-dot (<zielmailadresse>): 451 4.3.0 Error: queue file write error
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal amavis[1430]: (01430-11) (!)FWD via SMTP: <www-data@meinedomain.de> -> <ziel@mail.de>,BODY=7BIT 451 4.3.0 from MTA([127.0.0.1]:10025): 451 4.3.0 Error: queue file write error
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal amavis[1430]: (01430-11) Blocked MTA-BLOCKED, <www-data@meinedomain.de> -> <zielmal@mail.de>, Message-ID: <20130304210314.933AD17420D@meinedomain.de>, mail_id: agX+WxDMmps3, Hits: 1.939, size: 902, 248 ms
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal postfix/cleanup[4334]: warning: proxy:mysql:/etc/postfix/mysql_virtual_alias_maps.cf lookup error for "postmaster@meinedomain.de"
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal postfix/cleanup[4334]: warning: D924917420C: virtual_alias_maps map lookup problem for postmaster@meinedomain.de -- deferring delivery
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal postfix/smtpd[4338]: disconnect from localhost[127.0.0.1]
Mar 4 22:03:14 Ubuntu-1204-precise-64-minimal postfix/smtp[4335]: 933AD17420D: to=<ziel@mail.de>, relay=127.0.0.1[127.0.0.1]:10024, delay=0.3, delays=0.03/0.02/0.01/0.25, dsn=4.3.0, status=deferred (host 127.0.0.1[127.0.0.1] said: 451 4.3.0 id=01430-11 - Temporary MTA failure on relaying, from MTA([127.0.0.1]:10025): 451 4.3.0 Error: queue file write error (in reply to end of DATA command))
Mar 4 22:04:11 Ubuntu-1204-precise-64-minimal postfix/smtpd[3760]: connect from dub0-omc2-s11.dub0.hotmail.com[157.55.1.150]
Mar 4 22:04:12 Ubuntu-1204-precise-64-minimal postfix/smtpd[3760]: NOQUEUE: reject: RCPT from dub0-omc2-s11.dub0.hotmail.com[157.55.1.150]: 451 4.3.0 <meinemail@hotmail.de>: Temporary lookup failure; from=<meinemail@hotmail.de> to=<admin@meinedomain.de> proto=ESMTP helo=<dub0-omc2-s11.dub0.hotmail.com>
Mar 4 22:04:12 Ubuntu-1204-precise-64-minimal postfix/smtpd[3760]: disconnect from dub0-omc2-s11.dub0.hotmail.com[157.55.1.150]
Mar 4 22:04:17 Ubuntu-1204-precise-64-minimal postfix/smtpd[3760]: connect from dub0-omc3-s26.dub0.hotmail.com[157.55.2.35]
Mar 4 22:04:17 Ubuntu-1204-precise-64-minimal postfix/smtpd[3760]: NOQUEUE: reject: RCPT from dub0-omc3-s26.dub0.hotmail.com[157.55.2.35]: 451 4.3.0 <meinemail@hotmail.de>: Temporary lookup failure; from=<meinemail@hotmail.de> to=<admin@meinedomain.de> proto=ESMTP helo=<dub0-omc3-s26.dub0.hotmail.com>
Mar 4 22:04:17 Ubuntu-1204-precise-64-minimal postfix/smtpd[3760]: disconnect from dub0-omc3-s26.dub0.hotmail.com[157.55.2.35]
Mar 4 22:04:18 Ubuntu-1204-precise-64-minimal postfix/smtpd[3760]: connect from unknown[178.126.116.67]
Mar 4 22:04:19 Ubuntu-1204-precise-64-minimal postfix/smtpd[3760]: NOQUEUE: reject: RCPT from unknown[178.126.116.67]: 451 4.3.0 <79b37ed3@wendovernv.com>: Temporary lookup failure; from=<79b37ed3@wendovernv.com> to=<snyder@oletuarte.com> proto=SMTP helo=<178.126.156.61>
Mar 4 22:04:19 Ubuntu-1204-precise-64-minimal postfix/smtpd[3760]: lost connection after RCPT from unknown[178.126.116.67]
Mar 4 22:04:19 Ubuntu-1204-precise-64-minimal postfix/smtpd[3760]: disconnect from unknown[178.126.116.67]
ubuman
ein update von ispconfig hat es nun getan ;) puuuuh war ich froh :)
nun interagiert das system.. habe unter squirrelmail ein konto angelegt welches auch mails sendet..
1. die mails von admin@meinedomain.de werden z.b. unter hotmail als "junk" erkannt (erscheint also nicht unter inbox)
2. ich kann keine mails an admin@meinedomain.de senden
habt ihr einen vorschlag?
mfg
ubuman
nowayback
konten legt man in ispconfig an und nicht unter squirrelmail.
unter: mydestination = localhost, localhost.localdomain fehlt der eintrag des servers
ubuman
ich habe unter ispconfig ein konto angelegt..
info@meinedomain.de
habe auch zugriff auf das konto.. senden kann ich auch mails nur nicht empfangen.. ich versuche über mein hotmail konto eine mail zu senden..
bekomme aber immer die fehlermeldung im delivery report
diagnostic-code: x-postfix: unknown user: "info"
muss dann unter mydestination: localhost, localhost.localadmin, meinedomain.de rein?
ubuman
ja habe ich.. ich brauch ja hierfür keine subdomain oder? habe im isp eine email domain + ein email konto angelegt.. :(
ubuman
habe schon mehrere tage gelesen und konfiguriert.. es tut sich immer noch nichts.. der server empfängt keine mails.. bekomme die mails wieder zurück.. was brauch ich den alles um mails über postfix unter squirrelmail empfangen zu können? :confused:
ubuman
ein ausschnitt aus der mail.log
postfix/pipe[25980]: 944F7174205: to=<info@meinedomain.de>, relay=dovecot, delay=0.14, delays=0.02/0/0/0.11, dsn=4.3.0, status=deferred (temporary failure. Command output: lda: Error: user info@meinedomain.de: Error reading configuration: Invalid settings: postmaster_address setting not given lda: Fatal: Internal error occurred. Refer to server log for more information. )
postfix/qmgr[25659]: DFCC91741F9: removed
dovecot: imap-login: Login: user=<info@meinedomain.de>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=25988, secured
dovecot: imap(info@meinedomain.de): Disconnected: Logged out bytes=79/687
florian030
Und Du hast 'deliver -c' auch in der master.cf bei dovecot definiert?
Edit: nein, hast Du nicht - wenn ich das am Anfang des Threads richtig sehe.....
Etwas in der Art:
   flags=DRhu user=vmail argv=/usr/lib/dovecot/deliver -c /etc/dovecot/dovecot-postfix.conf -f ${sender} -d ${recipient}
ubuman
doch das hatte ich drinne.. nun schaut meine main.cf & master.cf so aus.. es tut sich immer noch nichts.. mails kann ich senden aber keine empfangen :(
main.cf
# is /etc/mailname.
biff = no
# TLS parameters
smtpd_use_tls = yes
relayhost =
smtp_use_tls = yes
# No open relay!
ubuman
master.cf schaut so aus..
${nexthop} ${user}
-o content_filter=
ubuman
beim restart von dovecot gibt es keine probleme
dovecot -n spuckt das aus
# 2.0.19: /etc/dovecot/dovecot.conf
# OS: Linux 3.2.0-38-generic x86_64 Ubuntu 12.04.2 LTS
auth_mechanisms = plain login
disable_plaintext_auth = no
listen = *,[::]
log_timestamp = "%Y-%m-%d %H:%M:%S "
mail_privileged_group = vmail
managesieve_notify_capability = mailto
managesieve_sieve_capability = fileinto reject envelope encoded-character vacation subaddress comparator-i;ascii-numeric relational regex imap4flags copy include variables body enotify environment mailbox date ihave
passdb {
args = /etc/dovecot/dovecot-sql.conf
driver = sql
plugin {
quota = dict:user::file:/var/vmail/%d/%n/.quotausage
sieve = /var/vmail/%d/%n/.sieve
protocols = imap pop3
service auth {
unix_listener /var/spool/postfix/private/auth {
group = postfix
mode = 0660
user = postfix
unix_listener auth-userdb {
group = vmail
mode = 0600
user = vmail
user = root
ssl_cert = </etc/postfix/smtpd.cert
ssl_key = </etc/postfix/smtpd.key
userdb {
driver = sql
protocol imap {
mail_plugins = quota imap_quota
protocol pop3 {
pop3_uidl_format = %08Xu%08Xv
protocol lda {
mail_plugins = sieve quota
in der mail.log sind immer die selben sachen.. nichts anderes :(
