Postfix RBL geht nicht?
DripleX
ich habe seit einiger Zeit ein großes SPAM-Aufkommen. Deshalb wollte ich Postfix RBL einrichten.
Hier mal mein main.cf
# Debian specific:  Specifying a file name will cause the first
# line of that file to be used as the name.  The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
# TLS parameters
smtpd_use_tls = yes
myhostname = XXXXXXX.yourvserver.net
alias_maps = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
alias_database = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
mydestination = XXXXXXX.yourvserver.net, localhost, localhost.localdomain
relayhost =
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
virtual_alias_domains =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, proxy:mysql:/etc/postfix/mysql-virtual_email2email.cf, hash:/var/lib/mailman/data/virtual-mailman
inet_protocols = all
smtpd_sasl_auth_enable = yes
smtpd_recipient_restrictions = check_recipient_access mysql:/etc/postfix/mysql-virtual_recipient.cf, permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination, reject_rbl_client bl.spamcop.net, reject_rbl_client dul.dnsbl.sorbs.net, reject_rbl_client cbl.abuseat.org, reject_rbl_client mail.bl.blocklist.de, reject_rbl_client imap.bl.blocklist.de, permit
transport_maps = hash:/var/lib/mailman/data/transport-mailman, proxy:mysql:/etc/postfix/mysql-virtual_transports.cf
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks
smtpd_client_message_rate_limit = 100
virtual_transport = dovecot
owner_request_special = no
smtpd_sasl_type = dovecot
receive_override_options = no_address_mappings, no_milters
message_size_limit = 0
smtpd_tls_CAfile = /usr/local/ispconfig/interface/ssl/startssl.chain.class1.server.crt
smtp_tls_security_level = may
milter_default_action = accept
milter_protocol = 6
smtpd_milters = inet:localhost:4526
non_smtpd_milters = inet:localhost:4526
Ich habe das nach mehreren HOWTOS im Internet erstellt. Es muss zum Teil auch funktioniert haben, da ein RBL Server einige meiner eigenen E-Mails blockiert hat. Diesen Server habe ich dann entfernt.
Da der SPAM eben nicht weniger geworden ist, hab ich im Internet einen Test gefunden mit dem man die RBL Rules testen kann.
Man muss einfach eine E-Mail an "nelson-sbl-test@crynwr.com" senden und bekommt eine Antwortmail mit Ergebnis. Bei mir war dieses negativ.
Kann natürlich auch sein, dass der Test auch nicht sicher funktioniert.
Deshalb die Frage, ob meine main.cf Konfiguration so richtig ist und ob ich noch was verbessern kann?
Momentan bekomme ich ganz viele SPAM Mails von .eu Adressen z.B. hier ein whois WonderingAboutInThought.eu WHOIS, DNS, & Domain Info - DomainTools
Was könnte ich noch gegen den SPAM machen?
xabbu
Hi,
ich habe die besten Erfahrungen mit postscreen und anschl. Greylisting sowie Amavis gemacht.
Bei Interesse, kann ich Dir ja mal meine Konfig zeigen.
LG
xabbu
DripleX
Danke für deine schnelle Antwort und Konfiguration.
Leider konnte ich es wegen eines Umzugs noch nicht testen.
Wenn ich Zeit finde, werde ich es testen und berichte dann das Ergebnis.
DripleX
Servus,
wäre es vielleicht möglich, dass du nochmal deine Konfiguration postest?
Der Link oben geht nämlich nicht mehr.
DripleX
Vielen Dank!
Ich habe die Datei nun gespeichert. Wenn ich dann mal wieder Zeit habe, werde ich es testen und berichten.
DripleX
So, ich habe nun seit über einer Woche deine Konfiguration am Laufen.
Leider ist diese auch nicht besser als meine Alte. Das SPAM Aufkommen ist nicht besser geworden.
Hier meine aktuelle Konfiguration: http://pastebin.com/BMM8ZNji
Habe ich vielleicht was übersehen oder falsch gemacht?
