Postfix Problem
brodie
ich habe von einer Weile auf einem Server ein 2.2.25 installiert. Davor habe ich das PerfectSetup für Ubuntu 8.04 LTS fertigsgestellt. Ich habe aber noch ein Problem mit dem Postfix:
Meine main.cf sieht so aus
# Debian specific:  Specifying a file name will cause the first
# line of that file to be used as the name.  The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
readme_directory = no
# TLS parameters
smtpd_use_tls = yes
myhostname = ...
#mydestination = ..., localhost, localhost.localdomain
relayhost =
mynetworks = 127.0.0.0/8
mailbox_command =
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
inet_protocols = all
smtpd_sasl_local_domain =
smtpd_sasl_auth_enable = yes
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, check_recipient_access mysql:/etc/postfix/mysql-virtual_recipient.cf, reject_una$
smtpd_tls_auth_only = no
smtp_use_tls = yes
smtpd_tls_CAfile = /etc/postfix/ssl/cacert.pem
smtpd_tls_loglevel = 1
home_mailbox = Maildir/
virtual_alias_domains =
#virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, mysql:/etc/postfix/mysql-virtual_email2email.cf
virtual_mailbox_base = /home/vmail
virtual_create_maildirsize = yes
virtual_mailbox_extended = yes
virtual_mailbox_limit_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailbox_limit_maps.cf
virtual_mailbox_limit_override = yes
virtual_maildir_limit_message = "The user you are trying to reach is over quota."
virtual_overquota_bounce = yes
proxy_read_maps = $local_recipient_maps $#mydestination $#virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_rec$
virtual_transport = maildrop
virtual_maps = hash:/etc/postfix/virtusertable
Alles was im mail.err steht ist:
Oct 29 16:46:38 predator postfix/proxymap[17406]: fatal: dictionary mail_dict: macro processing error
Ich kenn mich auf dem Gebiet nun nicht wirklich aus. Kann man anhand der main.cf ein Problem sehen oder braucht es noch mehr Infos?
Edit: Noch eine Sache. Ich habe wohl bei der Installation vom Postfix das mysql-Packet postfix-mysql vergessen gehabt. Wie auch immer ich das geschafft habe. Das war jedenfalls das erste Problem, welches Postfix hatte. Das habe ich dann nachträglich, also nach der ISPConfig Installation noch hinterher installiert. Vielleicht ist das auch ein Problem, dass so die Konfiguration nicht geklappt hat?
Vielen Dank,
brodie
Deine Postfix Konfiguration ist nicht kompatibel mit ISPConfig 2. postfix-mysql wird von ISPConfig 2 nicht verwendet und sollte nicht installiert sein! So wie Dein Setup aussieht, wurde es nicht nach dem perfect setup guide installiert sondern Du hast einen postfix mit virtuellen Usern konfiguriert, was inkompatibel mit ISPConfig 2 ist und muss komplett entfernt werden.
