Ich hatte bisher nur openvz mit squeeze und wollte nun einen neuen Server mit wheezy und habe nach:
Installing And Using OpenVZ On Debian Wheezy (AMD64) | HowtoForge - Linux Howtos and Tutorials
versucht den Kernel zu installieren:
das Verzeichnis /etc/init.d/vz iist nicht vorhanden
root@Debian-75-wheezy-64-LAMP /tmp # dpkg -i vz*.deb ploop*.deb
(Reading database ... 69226 files and directories currently installed.)
Preparing to replace vzctl-core 4.7.2-1 (using vzctl-core_4.7.2-1_amd64.deb) ...
Unpacking replacement vzctl-core ...
Preparing to replace vzkernel 2.6.32-042stab088.4 (using vzkernel_2.6.32-042stab088.4_amd64.deb) ...
update-initramfs: Deleting /boot/initrd.img-2.6.32-042stab088.4
Unpacking replacement vzkernel ...
Generating grub.cfg ...
Found linux image: /boot/vmlinuz-2.6.32-042stab088.4
done
Preparing to replace vzkernel-devel 2.6.32-042stab088.4 (using vzkernel-devel_2.6.32-042stab088.4_amd64.deb) ...
Unpacking replacement vzkernel-devel ...
Preparing to replace vzquota 3.1-1 (using vzquota_3.1-1_amd64.deb) ...
Unpacking replacement vzquota ...
Preparing to replace ploop 1.11-1 (using ploop_1.11-1_amd64.deb) ...
Unpacking replacement ploop ...
Preparing to replace ploop-lib 1.11-1 (using ploop-lib_1.11-1_amd64.deb) ...
Unpacking replacement ploop-lib ...
Setting up vzctl-core (4.7.2-1) ...
Setting up vzkernel (2.6.32-042stab088.4) ...
update-initramfs: Generating /boot/initrd.img-2.6.32-042stab088.4
WARNING: could not open /lib/modules/2.6.32-042stab088.4/modules.builtin: No such file or directory
W: mdadm: /etc/mdadm/mdadm.conf defines no arrays.
W: mdadm: no arrays defined in configuration file.
WARNING: could not open /var/tmp/mkinitramfs_8DUhC2/lib/modules/2.6.32-042stab088.4/modules.builtin: No such file or directory
Found initrd image: /boot/initrd.img-2.6.32-042stab088.4
done
Setting up vzkernel-devel (2.6.32-042stab088.4) ...
Setting up vzquota (3.1-1) ...
Setting up ploop (1.11-1) ...
Setting up ploop-lib (1.11-1) ...
Processing triggers for man-db ...
update-rc.d vz defaults
update-rc.d: using dependency based boot sequencing
update-rc.d: error: unable to read /etc/init.d/vz
