simplemodus
Wenn Mails weggesendet werden dann gibts ein Relay denied,
wenn man Mails an die Adressen sendet ist es wie ein schwarzes Loch ... weg ist es ...
Mein Latein ist langsam am Ende. Bitte um Hilfe.
Mailversende Problem:
simplemodus@gmail.com am 25.11.2013 14:59
Serverfehler: "554 5.7.1 <simplemodus@gmail.com>: Relay access denied"'
/var/log/mail
Mailempfänger Problem:
/var/log/mail
Nov 25 14:59:28 junkie postfix/smtpd[20197]: connect from 77.117.92.183.wireless.dyn.drei.com[77.117.92.183]
Nov 25 14:59:28 junkie postfix/smtpd[20197]: NOQUEUE: reject: RCPT from 77.117.92.183.wireless.dyn.drei.com[77.117.92.183]: 554 5.7.1 <christian.peter@gmx.at>: Relay access denied; from=<simplemodus@i-i.at> to=<christian.peter@gmx.at> proto=ESMTP helo=<entenhausen>
Nov 25 14:59:28 junkie postfix/smtpd[20197]: NOQUEUE: reject: RCPT from 77.117.92.183.wireless.dyn.drei.com[77.117.92.183]: 554 5.7.1 <simplemodus@gmail.com>: Relay access denied; from=<simplemodus@i-i.at> to=<simplemodus@gmail.com> proto=ESMTP helo=<entenhausen>
Nov 25 14:59:32 junkie postfix/smtpd[20197]: disconnect from 77.117.92.183.wireless.dyn.drei.com[77.117.92.183]
Nov 25 15:00:02 junkie postfix/smtpd[20197]: connect from localhost[127.0.0.1]
Nov 25 15:00:02 junkie postfix/smtpd[20197]: lost connection after CONNECT from localhost[127.0.0.1]
Nov 25 15:00:02 junkie postfix/smtpd[20197]: disconnect from localhost[127.0.0.1]
Nov 25 15:00:02 junkie dovecot: pop3-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Nov 25 15:00:02 junkie dovecot: imap-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Nov 25 15:00:17 junkie postfix/smtpd[20197]: connect from localhost[127.0.0.1]
Nov 25 15:00:17 junkie postfix/smtpd[20197]: lost connection after CONNECT from localhost[127.0.0.1]
Nov 25 15:00:17 junkie postfix/smtpd[20197]: disconnect from localhost[127.0.0.1]
Nov 25 15:00:17 junkie dovecot: pop3-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Nov 25 15:00:17 junkie dovecot: imap-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Nov 25 15:19:51 junkie postfix/smtpd[20197]: connect from 77.117.92.183.wireless.dyn.drei.com[77.117.92.183]
Nov 25 15:19:52 junkie postfix/smtpd[20197]: NOQUEUE: reject: RCPT from 77.117.92.183.wireless.dyn.drei.com[77.117.92.183]: 554 5.7.1 <christian.peter@gmx.at>: Relay access denied; from=<simplemodus@i-i.at> to=<christian.peter@gmx.at> proto=ESMTP helo=<entenhausen>
Nov 25 15:19:52 junkie postfix/smtpd[20197]: NOQUEUE: reject: RCPT from 77.117.92.183.wireless.dyn.drei.com[77.117.92.183]: 554 5.7.1 <simplemodus@gmail.com>: Relay access denied; from=<simplemodus@i-i.at> to=<simplemodus@gmail.com> proto=ESMTP helo=<entenhausen>
Nov 25 15:19:53 junkie dovecot: imap-login: Login: user=<simplemodus@i-i.at>, method=PLAIN, rip=77.117.92.183, lip=213.164.17.33
Nov 25 15:19:55 junkie dovecot: imap-login: Login: user=<simplemodus@i-i.at>, method=PLAIN, rip=77.117.92.183, lip=213.164.17.33
Nov 25 15:19:56 junkie dovecot: imap-login: Login: user=<ch.peter@i-i.at>, method=PLAIN, rip=77.117.92.183, lip=213.164.17.33
Nov 25 15:19:57 junkie dovecot: imap-login: Login: user=<ch.peter@i-i.at>, method=PLAIN, rip=77.117.92.183, lip=213.164.17.33
Nov 25 15:20:01 junkie dovecot: imap-login: Login: user=<simplemodus@i-i.at>, method=PLAIN, rip=77.117.92.183, lip=213.164.17.33
Nov 25 15:20:01 junkie postfix/smtpd[20197]: disconnect from 77.117.92.183.wireless.dyn.drei.com[77.117.92.183]
Nov 25 15:20:02 junkie postfix/smtpd[20197]: connect from localhost[127.0.0.1]
Nov 25 15:20:02 junkie postfix/smtpd[20197]: lost connection after CONNECT from localhost[127.0.0.1]
Nov 25 15:20:02 junkie postfix/smtpd[20197]: disconnect from localhost[127.0.0.1]
Nov 25 15:20:02 junkie dovecot: pop3-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Nov 25 15:20:02 junkie dovecot: imap-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Nov 25 15:03:00 junkie dovecot: imap-login: Login: user=<ch.peter@i-i.at>, method=PLAIN, rip=77.117.92.183, lip=213.164.17.33
Nov 25 15:03:00 junkie postfix/smtpd[20197]: connect from mout.gmx.net[212.227.17.22]
Nov 25 15:03:00 junkie postfix/cleanup[21007]: warning: database /etc/postfix/sender_canonical.db is older than source file /etc/postfix/sender_canonical
Nov 25 15:03:00 junkie postfix/smtpd[20197]: C1AB74096C: client=mout.gmx.net[212.227.17.22]
Nov 25 15:03:00 junkie postfix/cleanup[21007]: C1AB74096C: message-id=<!&!AAAAAAAAAAAYAAAAAAAAANOyUCd/zBVFv72vR/daHthCkAAAEAAAAAd7PhefIsNFvE9FC/zZ15IBAAAAAA==@gmx.at>
Nov 25 15:03:00 junkie postfix/qmgr[15644]: C1AB74096C: from=<christian.peter@gmx.at>, size=25831, nrcpt=1 (queue active)
Nov 25 15:03:00 junkie postfix/smtp[21008]: connect to 127.0.0.1[127.0.0.1]:10024: Connection refused
Nov 25 15:03:00 junkie postfix/smtpd[20197]: disconnect from mout.gmx.net[212.227.17.22]
Nov 25 15:03:00 junkie postfix/smtp[21008]: C1AB74096C: to=<ch.peter@i-i.at>, relay=none, delay=0.17, delays=0.16/0.01/0/0, dsn=4.4.1, status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Nov 25 15:03:00 junkie postfix/qmgr[15644]: warning: private/amavis socket: malformed response
Nov 25 15:03:00 junkie postfix/qmgr[15644]: warning: transport amavis failure -- see a previous warning/fatal/panic logfile record for the problem description
Nov 25 15:03:00 junkie postfix/master[14959]: warning: process /usr/lib/postfix/smtp pid 21008 killed by signal 6
Nov 25 15:03:00 junkie postfix/master[14959]: warning: /usr/lib/postfix/smtp: bad command startup -- throttling
Nov 25 15:03:00 junkie postfix/error[21011]: C1AB74096C: to=<ch.peter@i-i.at>, relay=none, delay=0.22, delays=0.16/0.04/0/0.02, dsn=4.3.0, status=deferred (unknown mail transport error)
Nov 25 15:03:01 junkie postfix/smtpd[20197]: connect from localhost[127.0.0.1]
Nov 25 15:03:01 junkie postfix/smtpd[20197]: lost connection after CONNECT from localhost[127.0.0.1]
Nov 25 15:03:01 junkie postfix/smtpd[20197]: disconnect from localhost[127.0.0.1]
Nov 25 15:03:01 junkie dovecot: pop3-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Nov 25 15:03:01 junkie dovecot: imap-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Nov 25 15:03:02 junkie dovecot: imap-login: Login: user=<ch.peter@i-i.at>, method=PLAIN, rip=77.117.92.183, lip=213.164.17.33
Nov 25 15:03:02 junkie dovecot: imap-login: Login: user=<simplemodus@i-i.at>, method=PLAIN, rip=77.117.92.183, lip=213.164.17.33
