System auf Proxmox Root server pve-manager/5.4-14/b0e640f7 (Debian Stretch)
Läuft ein Buster Container auf einem Stretch Root?
Nach Installation kommt beim Starten von mariadb die Meldung.
systemctl status mariadb.service
* mariadb.service - MariaDB 10.3.22 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2020-05-09 07:55:52 UTC; 3min 17s ago
Docs: man:mysqld(8)
https://mariadb.com/kb/en/library/systemd/
Process: 298 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=226/NAMESPACE)
May 09 07:55:52 xxx systemd[1]: Starting MariaDB 10.3.22 database server...
May 09 07:55:52 xxx systemd[298]: mariadb.service: Failed to set up mount namespacing: Permission denied
May 09 07:55:52 xxx systemd[298]: mariadb.service: Failed at step NAMESPACE spawning /usr/bin/install: Permission denied
May 09 07:55:52 xxx systemd[1]: mariadb.service: Control process exited, code=exited, status=226/NAMESPACE
May 09 07:55:52 xxx systemd[1]: mariadb.service: Failed with result 'exit-code'.
May 09 07:55:52 xxx systemd[1]: Failed to start MariaDB 10.3.22 database server.
