Wichtiges Sicherheitsupdate für ISPConfig veröffentlicht
ISPConfig 3.0.4.4 is available for download. This release is a bugfix release for ISPConfig 3.0.4.
This release contains a critical security patch for webdav users:
FS#2157 : "Add new Webdav user" can chmod and chown entire server from client interface
It is highly recommended to install the 3.0.4.4 update immediately.
If installing the full update is not possible on your server,
then install the patch manually:
cd /tmp
wget http://www.ispconfig.org/downloads/webdav_user_edit_php.gz
gzip -d webdav_user_edit_php.gz
mv -f webdav_user_edit_php /usr/local/ispconfig/interface/web/sites/webdav_user_edit.php
For a detailed list of changes, please see the changelog section below.
*** New! The ISPConfig 3 manual is now available! ***
Version 1.3 for ISPConfig >= 3.0.4 (Date: 10/25/2011)
Author: Falko Timme <ft@falkotimme.com>
333 pages
The manual can be downloaded from these two links:
ISPConfig 3 Manual « ISPConfig – Hosting Control Panel
Version 1.3 Of The ISPConfig 3 Manual (Date: 10/25/2011) Available | HowtoForge - Linux Howtos and Tutorials
- Download
http://prdownloads.sourceforge.net/ispconfig/ISPConfig-3.0.4.4.tar.gz
- Changelog
=]ISPConfig::ISPConfig 3: Tasklist
- Known Issues:
- BUG Reporting
- Supported Linux Distributions
- Debian Etch (4.0) - Squeeze (6.0) and Debian testing
- Ubuntu 7.10 - 11.10
- OpenSuSE 11 - 12.1
- CentOS 5.2 - 6.2
- Fedora 9 - 15
- Installation
Documentation « ISPConfig – Hosting Control Panel
- Update
ispconfig_update.sh
Select "stable" as the update resource. The script will check if an updated version of ISPConfig 3 is available and then download the tar.gz and start the setup script.
How to Update ISPConfig 3 « FAQforge
- Manual update instructions
cd /tmp
cd ispconfig3_install/install
php -q update.php
planet_fox
Super-Moderator
hi
Installer bleibt bei folgendem stehn.
ispconfig3_install/interface/lib/classes/validate_database.inc.php
ispconfig3_install/interface/lib/classes/tform.inc.php
ispconfig3_install/interface/lib/classes/simplepie.inc.php
ispconfig3_install/interface/lib/classes/tpl_error.inc.php
ispconfig3_install/interface/lib/classes/validate_client.inc.php
ispconfig3_install/interface/lib/classes/validate_cron.inc.php
ispconfig3_install/interface/lib/classes/plugin_listview.inc.php
ispconfig3_install/interface/lib/classes/plugin.inc.php
ispconfig3_install/interface/lib/classes/tpl.inc.php
ispconfig3_install/interface/lib/classes/searchform_tpl_generator.inc.php
ispconfig3_install/interface/lib/classes/remoting.inc.php
is
Entweder die Festplatte ist voll oder Deine Shell zeigt nichts weiter an, drücke einfach mal return.
Die Version wird sofort hochgezählt. Es kann aber sein dass Du Dich seit dem Update nicht neu eingeloggt hast und die alte Versionsnummer noch in der Session steht.
