Feb 5 13:46:05 tux postfix/master[11235]: warning: process /usr/lib/postfix/smtp pid 11767 exit status 1
Feb 5 13:46:05 tux postfix/master[11235]: warning: /usr/lib/postfix/smtp: bad command startup -- throttling
Feb 5 13:46:05 tux postfix/qmgr[11237]: warning: private/amavis socket: malformed response
Feb 5 13:46:05 tux postfix/qmgr[11237]: warning: transport amavis failure -- see a previous warning/fatal/panic logfile record for the problem description
Feb 5 13:46:05 tux postfix/master[11235]: warning: process /usr/lib/postfix/smtp pid 11766 exit status 1
Feb 5 13:46:05 tux postfix/error[11768]: 7685135ECA9: to=<postmaster@7ox.de>, relay=none, delay=135964, delays=135963/1.1/0/0.06, dsn=4.3.0, status=deferred (unknown mail transport error)
Feb 5 13:46:05 tux postfix/error[11769]: A86C135EC82: to=<postmaster@7ox.de>, relay=none, delay=222364, delays=222363/1/0/0.08, dsn=4.3.0, status=deferred (unknown mail transport error)
Feb 5 13:46:05 tux postfix/error[11771]: CA0F935ECAE: to=<postmaster@7ox.de>, relay=none, delay=49564, delays=49563/1.1/0/0.05, dsn=4.3.0, status=deferred (unknown mail transport error)
Feb 5 13:47:04 tux amavis[11793]: starting. /usr/sbin/amavisd-new at tux.erding.lan amavisd-new-2.4.2 (20060627), Unicode aware, LANG=de_DE.UTF-8
Feb 5 13:47:04 tux amavis[11793]: Perl version 5.008008
Feb 5 13:47:05 tux amavis[11799]: Module Amavis::Conf 2.068
Feb 5 13:47:05 tux amavis[11799]: Module Archive::Tar 1.31
Feb 5 13:47:05 tux amavis[11799]: Module Archive::Zip 1.18
Feb 5 13:47:05 tux amavis[11799]: Module BerkeleyDB 0.31
Feb 5 13:47:05 tux amavis[11799]: Module Compress::Zlib 2.005
Feb 5 13:47:05 tux amavis[11799]: Module Convert::TNEF 0.17
Feb 5 13:47:05 tux amavis[11799]: Module Convert::UUlib 1.06
Feb 5 13:47:05 tux amavis[11799]: Module DBD::mysql 4.004
Feb 5 13:47:05 tux amavis[11799]: Module DBI 1.57
Feb 5 13:47:05 tux amavis[11799]: Module DB_File 1.814
Feb 5 13:47:05 tux amavis[11799]: Module Digest::MD5 2.36
Feb 5 13:47:05 tux amavis[11799]: Module MIME::Entity 5.420
Feb 5 13:47:05 tux amavis[11799]: Module MIME::Parser 5.420
Feb 5 13:47:05 tux amavis[11799]: Module MIME::Tools 5.420
Feb 5 13:47:05 tux amavis[11799]: Module Mail::Header 1.74
Feb 5 13:47:05 tux amavis[11799]: Module Mail::Internet 1.74
Feb 5 13:47:05 tux amavis[11799]: Module Mail::SpamAssassin 3.002003
Feb 5 13:47:05 tux amavis[11799]: Module Net::Cmd 2.26
Feb 5 13:47:05 tux amavis[11799]: Module Net::DNS 0.60
Feb 5 13:47:05 tux amavis[11799]: Module Net::SMTP 2.29
Feb 5 13:47:05 tux amavis[11799]: Module Net::Server 0.94
Feb 5 13:47:05 tux amavis[11799]: Module Razor2::Client::Version 2.81
Feb 5 13:47:05 tux amavis[11799]: Module Time::HiRes 1.86
Feb 5 13:47:05 tux amavis[11799]: Module Unix::Syslog 0.100
Feb 5 13:47:05 tux amavis[11799]: Amavis::DB code loaded
Feb 5 13:47:05 tux amavis[11799]: Amavis::Cache code loaded
Feb 5 13:47:05 tux amavis[11799]: SQL base code NOT loaded
Feb 5 13:47:05 tux amavis[11799]: SQL::Log code NOT loaded
Feb 5 13:47:05 tux amavis[11799]: SQL::Quarantine NOT loaded
Feb 5 13:47:05 tux amavis[11799]: Lookup::SQL code NOT loaded
Feb 5 13:47:05 tux amavis[11799]: Lookup::LDAP code NOT loaded
Feb 5 13:47:05 tux amavis[11799]: AM.PDP-in proto code loaded
Feb 5 13:47:05 tux amavis[11799]: SMTP-in proto code loaded
Feb 5 13:47:05 tux amavis[11799]: Courier proto code NOT loaded
Feb 5 13:47:05 tux amavis[11799]: SMTP-out proto code loaded
Feb 5 13:47:05 tux amavis[11799]: Pipe-out proto code NOT loaded
Feb 5 13:47:05 tux amavis[11799]: BSMTP-out proto code NOT loaded
Feb 5 13:47:05 tux amavis[11799]: Local-out proto code loaded
Feb 5 13:47:05 tux amavis[11799]: OS_Fingerprint code NOT loaded
Feb 5 13:47:05 tux amavis[11799]: ANTI-VIRUS code loaded
Feb 5 13:47:05 tux amavis[11799]: ANTI-SPAM code loaded
Feb 5 13:47:05 tux amavis[11799]: ANTI-SPAM-SA code loaded
Feb 5 13:47:05 tux amavis[11799]: Unpackers code loaded
Feb 5 13:47:05 tux amavis[11799]: Found $file at /usr/bin/file
Feb 5 13:47:05 tux amavis[11799]: No $dspam, not using it
Feb 5 13:47:05 tux amavis[11799]: Internal decoder for .mail
Feb 5 13:47:05 tux amavis[11799]: Internal decoder for .asc
Feb 5 13:47:05 tux amavis[11799]: Internal decoder for .uue
Feb 5 13:47:05 tux amavis[11799]: Internal decoder for .hqx
Feb 5 13:47:05 tux amavis[11799]: Internal decoder for .ync
Feb 5 13:47:05 tux amavis[11799]: No decoder for .F tried: unfreeze, freeze -d, melt, fcat
Feb 5 13:47:05 tux amavis[11799]: Found decoder for .Z at /bin/uncompress
Feb 5 13:47:05 tux amavis[11799]: Internal decoder for .gz
Feb 5 13:47:05 tux amavis[11799]: Found decoder for .bz2 at /bin/bzip2 -d
Feb 5 13:47:05 tux amavis[11799]: Found decoder for .lzo at /usr/bin/lzop -d
Feb 5 13:47:05 tux amavis[11799]: No decoder for .rpm tried: rpm2cpio.pl, rpm2cpio
Feb 5 13:47:05 tux amavis[11799]: Found decoder for .cpio at /usr/bin/pax
Feb 5 13:47:05 tux amavis[11799]: Found decoder for .tar at /usr/bin/pax
Feb 5 13:47:05 tux amavis[11799]: Found decoder for .deb at /usr/bin/ar
Feb 5 13:47:05 tux amavis[11799]: Internal decoder for .zip
Feb 5 13:47:05 tux amavis[11799]: No decoder for .rar tried: rar, unrar
Feb 5 13:47:05 tux amavis[11799]: No decoder for .arj tried: arj, unarj
Feb 5 13:47:05 tux amavis[11799]: Found decoder for .arc at /usr/bin/nomarch
Feb 5 13:47:05 tux amavis[11799]: Found decoder for .zoo at /usr/bin/zoo
Feb 5 13:47:05 tux amavis[11799]: No decoder for .lha tried: lha
Feb 5 13:47:05 tux amavis[11799]: No decoder for .doc tried: ripole
Feb 5 13:47:05 tux amavis[11799]: No decoder for .cab tried: cabextract
Feb 5 13:47:05 tux amavis[11799]: No decoder for .tnef
Feb 5 13:47:05 tux amavis[11799]: Internal decoder for .tnef
Feb 5 13:47:05 tux amavis[11799]: No decoder for .exe tried: rar, unrar; lha; arj, unarj
Feb 5 13:47:05 tux amavis[11799]: Using internal av scanner code for (primary) ClamAV-clamd
Feb 5 13:47:05 tux amavis[11799]: Using internal av scanner code for (primary) check-jpeg
Feb 5 13:47:05 tux amavis[11799]: Found secondary av scanner ClamAV-clamscan at /usr/bin/clamscan
Feb 5 13:47:05 tux amavis[11799]: Creating db in /var/lib/amavis/db/; BerkeleyDB 0.31, libdb 4.4
