Pure-FTP keine Verbindung
Pure-FTP sagt es läuft, aber es ist kein Port offen.
service pure-ftpd-mysql status:
pure-ftpd-mysql.service
   Loaded: loaded (/etc/init.d/pure-ftpd-mysql; generated; vendor preset: enabled)
   Active: active (exited) since Tue 2021-05-11 13:14:17 CEST; 2min 2s ago
  Process: 1572 ExecStart=/etc/init.d/pure-ftpd-mysql start (code=exited, status=0/SUCCESS)
    Tasks: 0 (limit: 4915)
   CGroup: /system.slice/pure-ftpd-mysql.service
Mai 11 13:14:17 host2 systemd[1]: Starting pure-ftpd-mysql.service...
Mai 11 13:14:17 host2 systemd[1]: Started pure-ftpd-mysql.service.
netstat -tap | grep ftp ergibt kein resultat
tail -n 100 /var/log/syslog | grep ftp
May 11 13:17:38 host2 monit[570]: 'pure-ftpd' process is not running
May 11 13:17:38 host2 monit[570]: 'pure-ftpd' trying to restart
May 11 13:17:38 host2 monit[570]: 'pure-ftpd' start: '/etc/init.d/pure-ftpd-mysql start'
WinSCP Log:
. 2021-05-11 11:15:43.268 Session name: **** (Site)
. 2021-05-11 11:15:43.268 Host name: **** (IPv4, Port: 21)
. 2021-05-11 11:15:43.268 User name: **** (Password: No, Key file: No, Passphrase: No)
. 2021-05-11 11:15:43.268 Transfer Protocol: FTP
. 2021-05-11 11:15:43.268 Ping type: Dummy, Ping interval: 30 sec; Timeout: 30 sec
. 2021-05-11 11:15:43.268 Disable Nagle: No
. 2021-05-11 11:15:43.268 Proxy: None
. 2021-05-11 11:15:43.268 Send buffer: 262144
. 2021-05-11 11:15:43.268 UTF: Auto
. 2021-05-11 11:15:43.268 FTPS: None [Client certificate: No]
. 2021-05-11 11:15:43.268 FTP: Passive: No [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2021-05-11 11:15:43.268 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2021-05-11 11:15:43.268 Cache directory changes: Yes, Permanent: Yes
. 2021-05-11 11:15:43.268 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2021-05-11 11:15:43.268 Timezone offset: 0h 0m
Lass das test script laufen und poste die Ausgabe.
logifech
Active Member
Steht dein Server hinter einer Firewall oder Ähnlichem? Hast du eine passive Port range definiert und diese Port range in der Firewall geöffnet?
