ich habe den Server 2-mal nach Anleitung installiert .
Er sendet nun garnix mehr !
Wo liegt mein Fehler
main.cf
main.cf
# is /etc/mailname.
#myorigin = /etc/mailname
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
# See http://www.postfix.org/COMPATIBILITY_README.html -- default to 2 on
# fresh installs.
compatibility_level = 2
# TLS parameters
smtpd_use_tls = yes
smtpd_relay_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination
myhostname = heliport1
alias_maps = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
alias_database = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
mydestination = heliport1, localhost, localhost.localdomain
relayhost =
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
inet_protocols = all
virtual_alias_domains = proxy:mysql:/etc/postfix/mysql-virtual_alias_domains.cf
virtual_alias_maps = hash:/var/lib/mailman/data/virtual-mailman, proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, proxy:mysql:/etc/postfix/mysql-virtual_alias_maps.cf, proxy:mysql:/etc/postfix/mysql-virtual_email2email.cf
virtual_uid_maps = proxy:mysql:/etc/postfix/mysql-virtual_uids.cf
virtual_gid_maps = proxy:mysql:/etc/postfix/mysql-virtual_gids.cf
sender_bcc_maps = proxy:mysql:/etc/postfix/mysql-virtual_outgoing_bcc.cf
smtpd_sasl_auth_enable = yes
smtpd_restriction_classes = greylisting
greylisting = check_policy_service inet:127.0.0.1:10023
smtpd_recipient_restrictions = permit_mynetworks, reject_unknown_recipient_domain, reject_unlisted_recipient, check_recipient_access proxy:mysql:/etc/postfix/mysql-verify_recipients.cf, permit_sasl_authenticated, reject_non_fqdn_recipient, reject_unauth_destination, check_recipient_access proxy:mysql:/etc/postfix/mysql-virtual_recipient.cf, check_recipient_access mysql:/etc/postfix/mysql-virtual_policy_greylist.cf, check_policy_service unix:private/quota-status
transport_maps = hash:/var/lib/mailman/data/transport-mailman, proxy:mysql:/etc/postfix/mysql-virtual_transports.cf
relay_domains = proxy:mysql:/etc/postfix/mysql-virtual_relaydomains.cf
relay_recipient_maps = proxy:mysql:/etc/postfix/mysql-virtual_relayrecipientmaps.cf
smtpd_sender_login_maps = proxy:mysql:/etc/postfix/mysql-virtual_sender_login_maps.cf
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $sender_bcc_maps $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks $smtpd_sender_login_maps $virtual_uid_maps $virtual_gid_maps $smtpd_client_restrictions $smtpd_sender_restrictions $smtpd_recipient_restrictions $smtp_sasl_password_maps $sender_dependent_relayhost_maps
smtpd_helo_required = yes
smtpd_helo_restrictions = permit_mynetworks, check_helo_access regexp:/etc/postfix/helo_access, permit_sasl_authenticated, reject_invalid_helo_hostname, reject_non_fqdn_helo_hostname, check_helo_access regexp:/etc/postfix/blacklist_helo, ,reject_unknown_helo_hostname, permit
smtpd_sender_restrictions = check_sender_access proxy:mysql:/etc/postfix/mysql-virtual_sender.cf, check_sender_access regexp:/etc/postfix/tag_as_originating.re, permit_mynetworks, permit_sasl_authenticated, reject_non_fqdn_sender, reject_unlisted_sender, check_sender_access regexp:/etc/postfix/tag_as_foreign.re
smtpd_reject_unlisted_sender = no
smtpd_client_restrictions = check_client_access proxy:mysql:/etc/postfix/mysql-virtual_client.cf, permit_inet_interfaces, permit_mynetworks, permit_sasl_authenticated, reject_rbl_client zen.spamhaus.org, reject_unauth_pipelining , permit
smtpd_etrn_restrictions = permit_mynetworks, reject
smtpd_data_restrictions = permit_mynetworks, reject_unauth_pipelining, reject_multi_recipient_bounce, permit
smtpd_client_message_rate_limit = 100
virtual_transport = lmtp:unix:private/dovecot-lmtp
owner_request_special = no
smtp_tls_security_level = dane
smtpd_tls_mandatory_protocols = !SSLv2, !SSLv3
smtpd_tls_protocols = !SSLv2,!SSLv3
smtp_tls_protocols = !SSLv2,!SSLv3
smtpd_tls_exclude_ciphers = RC4, aNULL
smtp_tls_exclude_ciphers = RC4, aNULL
smtpd_tls_mandatory_ciphers = medium
tls_medium_cipherlist = ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA
tls_preempt_cipherlist = yes
address_verify_negative_refresh_time = 60s
enable_original_recipient = no
sender_dependent_relayhost_maps = proxy:mysql:/etc/postfix/mysql-virtual_sender-relayhost.cf
smtp_sasl_password_maps = proxy:mysql:/etc/postfix/mysql-virtual_sender-relayauth.cf, texthash:/etc/postfix/sasl_passwd
smtp_sender_dependent_authentication = yes
smtp_sasl_auth_enable = yes
smtp_sasl_security_options = noanonymous, noplaintext
smtp_sasl_tls_security_options = noanonymous
smtpd_forbidden_commands = CONNECT,GET,POST,USER,PASS
address_verify_sender_ttl = 15686s
smtp_dns_support_level = dnssec
smtpd_sasl_type = dovecot
content_filter = lmtp:[127.0.0.1]:10024
