Postfix/Amavis Problem
timur
Hallo Liebe Community,
Ich hab seit einigen Tagen einen Fehler, vermutlich nach dem update zustande gekommen.
Feb 10 13:15:40 server amavis[919]: (00919-16) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200210T131540-00919-T4TTTu2l/parts/p002 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464.
Feb 10 13:22:44 server amavis[13464]: (13464-02) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200210T132244-13464-YvYXHkIK/parts/p002 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464.
Feb 10 13:32:44 server amavis[13264]: (13264-09) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200210T132244-13264-IWqOaHSB/parts/p002 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464.
Feb 10 13:52:45 server amavis[23411]: (23411-03) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200210T135245-23411-AGJVlmpY/parts/p002 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464.
Feb 10 14:32:45 server amavis[3152]: (03152-05) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200210T143245-03152-qgDWo6M6/parts/p002 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464.
Feb 10 15:42:46 server amavis[17318]: (17318-19) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200210T150904-17318-QJrd24AH/parts/p002 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464.
hab auch schon einige Dinge bei Google gefunden, aber leider noch nichts hilfreiches.
Die Lösung steht in vielen posts hier im Forum sowie in jeder release note einer ISPConfig version .... Schon mal danach gesucht?
timur
So Till,
Ispconfig reconfigure Services <-- gelöst.
Und das Hauptanliegen, scheint auf den ersten Blick, auch gelöst zu sein. Falls nicht melde ich mich nochmal.
Vielen Dank!
timur
Hallo liebe Community,
ich knüpfe mal hier an,in den Email Fehler logs habe ich folgendes:
May 19 09:17:04 server amavis[20891]: (20891-05) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T091704-20891-LptTHksi/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN34> line 5815.
May 19 09:25:02 server amavis[20891]: (20891-12) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T091705-20891-IRPFX3KJ/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN46> line 10212.
May 19 09:35:02 server amavis[27718]: (27718-04) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T093502-27718-PPG0UBes/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN33> line 5815.
May 19 09:55:02 server amavis[27718]: (27718-17) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T093502-27718-dHMD9f69/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN45> line 5815.
May 19 10:35:02 server amavis[5380]: (05380-20) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T103502-05380-8mSSkcEf/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN49> line 5815.
May 19 11:45:03 server amavis[31738]: (31738-17) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T114502-31738-Q8OuCGtN/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN46> line 5815.
May 19 12:55:02 server amavis[30119]: (30119-07) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T125502-30119-AuFK3CSZ/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN36> line 5815.
May 19 14:05:02 server amavis[23348]: (23348-05) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T140502-23348-QKnPZn5l/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN34> line 5815.
May 19 15:15:02 server amavis[14215]: (14215-06) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T151502-14215-EiG9hOhQ/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN35> line 5815.
May 19 16:25:02 server amavis[29236]: (29236-19) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T162502-29236-C90k8Cac/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN48> line 5815.
May 19 17:35:02 server amavis[23163]: (23163-15) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T173502-23163-h9IaTux_/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN44> line 5815.
May 19 18:45:02 server amavis[17503]: (17503-12) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T184502-17503-30XgeBtq/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN41> line 5815.
May 19 19:55:02 server amavis[7490]: (07490-14) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T195502-07490-0Oj0sDV0/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN43> line 5815.
May 19 21:05:03 server amavis[3943]: (03943-07) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T210502-03943-lHW0CEgH/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN36> line 5815.
May 19 22:15:02 server amavis[30506]: (30506-03) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T221502-30506-fGw6iYPF/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN32> line 5815.
May 19 23:25:02 server amavis[23624]: (23624-01) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200519T232502-23624-_7HfgJF4/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN30> line 5815.
May 20 00:35:02 server amavis[18371]: (18371-02) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200520T003502-18371-RmupfUsN/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN31> line 5815.
May 20 01:45:02 server amavis[2984]: (02984-15) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200520T014502-02984-7G6KeZi4/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN44> line 5815.
May 20 02:55:02 server amavis[28735]: (28735-12) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200520T025502-28735-EOwNe6Q7/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN41> line 5815.
May 20 04:05:03 server amavis[22540]: (22540-09) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200520T040502-22540-lcT2wr_k/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN38> line 5815.
May 20 05:15:03 server amavis[12160]: (12160-11) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200520T051502-12160-NBeCEBWB/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN40> line 5815.
May 20 06:25:02 server amavis[8987]: (08987-05) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200520T062502-08987-quW8odo_/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN34> line 5815.
May 20 07:35:02 server amavis[32715]: (32715-05) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200520T073502-32715-fiQKXFEc/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN34> line 5815.
May 20 08:45:02 server amavis[15387]: (15387-19) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200520T084502-15387-SBrobVkh/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN48> line 5815.
May 20 09:55:02 server amavis[8761]: (08761-16) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200520T095502-08761-jdENEKM7/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN45> line 5815.
May 20 11:05:02 server amavis[32443]: (32443-17) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200520T110502-32443-buDqtjbF/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN46> line 5815.
May 20 12:15:02 server amavis[25612]: (25612-15) (!!)TROUBLE in check_mail: mime_decode-1 FAILED: Can't open file /var/lib/amavis/tmp/amavis-20200520T115928-25612-nbwKeWo5/parts/p005 for reading: Operation not permitted at /usr/sbin/amavisd-new line 10464, <GEN35> line 5815.
Hab ich ein Virus in den Mails ?
timur
Nein platte ist noch lange nicht voll...
ich hab mir sophos installiert und festgestellt das es ein Virus war der in der Mail steckte die in der Email Warteschlange hing...
dann habe ich diese Email gelöscht und nun scheint das Problem weg zu sein.
