Ich habe ein WebDAV Account erstellt.
Zugriff unter:
Mac OS Finder = GEHT
Cyberduck = GEHT
Upload per Curl = GEHT NICHT
Im /var/www/domain.tld/log/error.log steht:
zu Testzwecken habe ich http://www.webdav.org/neon/litmus/ geladen und mit SSL compiliert.
Ergebnis scheint ok zu sein:
curl wollte ich wie folgt benutzen:
Zugriff unter:
Cyberduck = GEHT
Digest: client used wrong authentication scheme `Basic':
make URL=https://serverdomain.tld/webdav/meinordner/ CREDS="username passwort" check
-> running `basic':
0. init.................. pass
1. begin................. pass
2. options............... pass
3. put_get............... pass
4. put_get_utf8_segment.. pass
5. put_no_parent......... pass
6. mkcol_over_plain...... pass
7. delete................ pass
8. delete_null........... pass
9. delete_fragment....... pass
10. mkcol................. pass
11. mkcol_again........... pass
12. delete_coll........... pass
13. mkcol_no_parent....... pass
14. mkcol_with_body....... pass
15. finish................ pass
<- summary for `basic': of 16 tests run: 16 passed, 0 failed. 100.0%
-> running `copymove':
2. copy_init............. pass
3. copy_simple........... pass
4. copy_overwrite........ pass
5. copy_nodestcoll....... pass
6. copy_cleanup.......... pass
7. copy_coll............. pass
8. copy_shallow.......... pass
9. move.................. pass
10. move_coll............. pass
11. move_cleanup.......... pass
12. finish................ pass
<- summary for `copymove': of 13 tests run: 13 passed, 0 failed. 100.0%
-> running `props':
2. propfind_invalid...... pass
3. propfind_invalid2..... pass
4. propfind_d0........... pass
5. propinit.............. pass
6. propset............... pass
7. propget............... pass
8. propextended.......... pass
9. propmove.............. pass
10. propget............... pass
11. propdeletes........... pass
12. propget............... pass
13. propreplace........... pass
14. propget............... pass
15. propnullns............ pass
16. propget............... pass
17. prophighunicode....... pass
18. propget............... pass
19. propremoveset......... pass
20. propget............... pass
21. propsetremove......... pass
22. propget............... pass
23. propvalnspace......... pass
24. propwformed........... pass
25. propinit.............. pass
26. propmanyns............ pass
27. propget............... pass
28. propcleanup........... pass
29. finish................ pass
<- summary for `props': of 30 tests run: 30 passed, 0 failed. 100.0%
-> running `locks':
3. precond............... pass
4. init_locks............ pass
5. put................... pass
6. lock_excl............. pass
7. discover.............. pass
8. refresh............... pass
9. notowner_modify....... pass
10. notowner_lock......... pass
11. owner_modify.......... pass
12. notowner_modify....... pass
13. notowner_lock......... pass
14. copy.................. pass
15. cond_put.............. pass
16. fail_cond_put......... pass
17. cond_put_with_not..... pass
18. cond_put_corrupt_token WARNING: PUT failed with 400 not 423
...................... pass (with 1 warning)
19. complex_cond_put...... pass
20. fail_complex_cond_put. pass
21. unlock................ pass
22. fail_cond_put_unlocked pass
23. lock_shared........... pass
24. notowner_modify....... pass
25. notowner_lock......... pass
26. owner_modify.......... pass
27. double_sharedlock..... pass
28. notowner_modify....... pass
29. notowner_lock......... pass
30. unlock................ pass
31. prep_collection....... pass
32. lock_collection....... pass
33. owner_modify.......... pass
34. notowner_modify....... pass
35. refresh............... pass
36. indirect_refresh...... pass
37. unlock................ pass
38. unmapped_lock......... WARNING: LOCK on unmapped url returned 200 not 201 (RFC4918:S7.3)
39. unlock................ pass
40. finish................ pass
<- summary for `locks': of 41 tests run: 41 passed, 0 failed. 100.0%
-> 2 warnings were issued.
-> running `http':
2. expect100............. SKIPPED (skipping for SSL server)
3. finish................ pass
-> 1 test was skipped.
<- summary for `http': of 3 tests run: 3 passed, 0 failed. 100.0%
curl -4 --basic -k -u username:passwort -T datei_upload https://serverdomain.tld/webdav/folder/
