ISPConfig3 für OpenBSD
Brainfood
Hallo Community,
ich würde gerne ISPConfig3 unter OpenBSD lauffähig machen, die einzige Prämisse wäre wohl der Verzicht auf Package-Updates (da diese sehr zeitaufwendig manuell unter OpenBSD gepflegt werden müssen) ...
Die fertigen Pre_Install_Skripte packe ich dann ins OpenSource www.ipfrog.de Image ...
Was ist alles für eine Dist.Anpassung notwendig?
/tmp/ispconfig3_install/install/lib/ ... files
/tmp/ispconfig3_install/dist/ ... files
spezifische in der ispconfig server verwaltung selbst?
Wie genau fragt der ISPConfig Installer die Distributionsversion ab?
get_distname ...?
Brainfood
ich habe soweit die install_files angepasst:
# php -q install.php
 _____ ___________   _____              __ _         ____
|_   _/  ___| ___ \ /  __ \            / _(_)       /__  \
  | | \ `--.| |_/ / | /  \/ ___  _ __ | |_ _  __ _    _/ /
  | |  `--. \  __/  | |    / _ \| '_ \|  _| |/ _` |  |_ |
 _| |_/\__/ / |     | \__/\ (_) | | | | | | | (_| | ___\ \
 \___/\____/\_|      \____/\___/|_| |_|_| |_|\__, | \____/
                                              __/ |
                                             |___/
>> Initial configuration
Operating System: OpenBSD 5.1 or compatible
    Following will be a few questions for primary configuration so be careful.
    Default values are in [brackets] and can be accepted with <ENTER>.
    Tap in "quit" (without the quotes) to stop the installer.
Select language (en,de) [en]:
Installation mode (standard,expert) [standard]:
Full qualified hostname (FQDN) of the server, eg server1.domain.tld  [srv48devel.plitc.eu]:
MySQL server hostname [localhost]:
MySQL root username [root]:
MySQL root password []: ispconfig
MySQL database to create [dbispconfig]:
MySQL charset [utf8]:
usage: useradd -D [-b base-directory] [-e expiry-time] [-f inactive-time]
               [-g gid | name | =uid] [-k skel-directory] [-L login-class]
               [-r low..high] [-s shell]
       useradd [-mov] [-b base-directory] [-c comment] [-d home-directory]
               [-G secondary-group[,group,...]] [-g gid | name | =uid]
               [-k skel-directory] [-L login-class] [-p password] [-r low..high]
               [-s shell] [-u uid] user
Generating a 2048 bit RSA private key
writing new private key to 'smtpd.key'
Country Name (2 letter code) []:DE
State or Province Name (full name) []:DE
Locality Name (eg, city) []:DE
Organization Name (eg, company) []:DE
Organizational Unit Name (eg, section) []:DE
Common Name (eg, fully qualified host name) []:DE
Email Address []:DE
chown: user is invalid: vmail
Configuring Jailkit
Configuring Dovecot
PHP Warning:  chmod(): No such file or directory in /tmp/ispconfig3_install/install/dist/lib/openbsd51.lib.php on line 99
PHP Warning:  chgrp(): Unable to find gid for root in /tmp/ispconfig3_install/install/dist/lib/openbsd51.lib.php on line 109
Configuring Spamassassin
Configuring Amavisd
Couldn't find /etc/adduser.conf: creating a new adduser configuration file
--- bleibt an dieser stelle hängen ---
PAM.D gibt es unter OpenBSD nicht ... kann man eine andere Authentifizierungs-Schnittstelle verwenden (z.B. openbsd-bsdauth) ?
Wenn nicht wird das ganze recht kompliziert ...
Pam.d wird von ispconfig nicht verwendet, es werden lediglich normale Linux Systemuser angelegt. Das mailsystem authentifiziert sich über dovecot-sql und nicht pam.
Brainfood
bin ein stück weiter:
                                              __/ |
                                             |___/
Installation mode (standard,expert) [standard]: expert
MySQL database to create [dbispconfig]: db_14
The next two questions are about the internal ISPConfig database user and password.
It is recommended to accept the defaults which are 'ispconfig' as username and a random password.
If you use a different password, use only numbers and chars for the password.
ISPConfig mysql database username [ispconfig]:
ISPConfig mysql database password [91986c5b1204ef849d74def5e5e4030d]:
Shall this server join an existing ISPConfig multiserver setup (y,n) [n]:
Adding ISPConfig server record to database.
Configure Mail (y,n) [y]:
Configuring Postfix
Email Address []:
Configuring Mailman
Configuring Dovecot
Configuring Amavisd
Illegal username. Please see the restrictions section of the man page.
^C
# Caught signal SIGINT -- cleaning up.
stty: tcsetattr: Input/output error
-m option von installer_base.lib.php gibts unter openbsd useradd nicht, also dann:
$command = 'useradd -g '.$cf['vmail_groupname'].' -u '.$cf['vmail_userid'].' -d '.$cf['vmail_mailbox_base'].' '.$cf['vmail_username'].' ';
unter openbsd nennt sich der amavis user: _vscan
wo ist er in den ispconfigs definiert?
Brainfood
wieder etwas weiter:
Anpassung: installer_base.lib.php
// Add the clamav user to the amavis group
                exec('usermod -G _vscan _clamav');
Configuring Amavisd
Configuring Getmail
Configuring Pureftpd
PHP Warning:  chgrp(): Unable to find gid for root in /tmp/ispconfig3_install/install/lib/installer_base.lib.php on line 1049
sh: cannot create /etc/pure-ftpd/conf/ChrootEveryone: No such file or directory
sh: cannot create /etc/pure-ftpd/conf/BrokenClientsCompatibility: No such file or directory
sh: cannot create /etc/pure-ftpd/conf/DisplayDotFiles: No such file or directory
sh: cannot create /etc/pure-ftpd/conf/DontResolve: No such file or directory
Configuring BIND
PHP Warning:  chgrp(): Unable to find gid for bind in /tmp/ispconfig3_install/install/lib/installer_base.lib.php on line 1147
Configuring Apache
PHP Warning:  symlink(): No such file or directory in /tmp/ispconfig3_install/install/lib/installer_base.lib.php on line 1209
Configuring Vlogger
PHP Warning:  chgrp(): Unable to find gid for root in /tmp/ispconfig3_install/install/lib/installer_base.lib.php on line 1413
Configuring Apps vhost
useradd: Warning: home directory `/var/www/apps' doesn't exist, and -m was not specified
Die installer_base.lib wird für eine Anpassungen es Installers nie geändert, stattdessen überschreibst Du die Unterfunktionen die geändert werde sollen in der bSD spezifischen Controllerklasse so wie es für alle Linux Distributionen gemacht wird.
Brainfood
ich wollte nur schauen ob das ganze ohne weiteres unter openbsd funktionsfähig ist, wenn dann alle änderungen in einer changelog zusammengefasst stehen, folgt eine saubere umsetzung:
                                              __/ |
                                             |___/
MySQL database to create [dbispconfig]: db_23
Email Address []:
Configuring Jailkit
Configuring Dovecot
Configuring Amavisd
Configuring Getmail
Configuring BIND
Configuring Apache
Configuring Vlogger
hättest du für Zeile 1209 ein Tipp, Till?
F4RR3LL
Active Member
Ich hab den ganzen Spaß schonmal für FreeBSD angefangen gehabt.
Würde mich freuen wenn Du es sauber und vor allem upgradefhähig hinbekommst.
Viel Erfolg.
Gruß Sven
Was steht denn in der zeile? Du hast die Datei ja wahrscheinlich schon verändert und ich weiß nicht auf welcher SVN Revision Dein aktueller Code basiert.
Brainfood
@F4RR3LL
Wir BSDler sind genug damit beschäftigt, ständig aus den Ports bauen zu müssen, eine schicke "apt-get update/upgrade" Funktion käme uns dann göttlich vor :D ... Linux / Debian mag zwar sehr einfach und schnell installiert und eingerichtet werden, wenn es jedoch an die Substanz geht ... fängt das gefrickel an ...
Ich hätte schon gerne unter der ISPConfig3 Haube ein FreeBSD auf ZFS oder nen OpenBSD mit vernünftigem Crypto-Framework für meine Hifn Karten am Start ...
@Till, ist ispconfig3-stable
Zeile 1209:
                if(!@is_link($vhost_conf_enabled_dir.'/000-ispconfig.conf')) {
                        symlink($vhost_conf_dir.'/ispconfig.conf',$vhost_conf_enabled_dir.'/000-ispconfig.conf');
Brainfood
Ach Till, hast etwas dagegen wenn ich die geänderte tar.gz hier als link reinstelle?
vielleicht animiert das jemanden mitzumachen ...
Wenn das ganze Open/Free-BSD Unterfangen mal etwas Licht am Ende des Tunnels bekommen sollte, vielleicht schaust du zum Schluss mal drüber und fügst es als optional unterstützte OS-Versionen mit in die stable/public rein ...
Das Konfigurationsverzeichnis für die apache vhosts existiert bei Dir scheinbar nicht. Es muss 2 Verzeichnisse geben, eiens für die vhosts und eines für die symlinks zu den vhosts umd diese aktivieren / deaktivieren zu können ohne sie zu löschen. Standradmäßig ist das /etc/apache2/sites-enabled und /etc/apache2/sites-available. Diese kannst Du ja in install/dist/conf/ für jede Distribution festlegen.
Kannst Du gerne machen.
Wenn es funktioniert dann nehmen wir das gerne mit auf. Das Problem was ich aktuell sehe ist dass Du die Änderugen auf Basis von stable machst, alle Entwickler aber auf basis von svn arbeiten. Es wird in den nächsten Tagen eine neue Major Version von ispconfig 3 veröffentlicht (3.0.5) in der ein Jahr Entwicklungszeit und somit sehr sehr viele Änderungen stecken, wenn Du jetzt auf Basis von stable was entwickelst werden wir das kaum mehr aufnehmen können oder es komplett neu entwickeln müssen. Es wäre besser wenn Du die Version aus dem svn welche die neue stable in wenigen Tagen sein wird nimmst.
