ispconfig insterlations fehler
torty
Schönen guten abend
habe das problem bei der install läuft so weit durch nur zum schluss kommt folgender fehler
See "systemctl status amavis.service" and "journalctl -xe" for details.
invoke-rc.d: initscript amavis, action "start" failed.
● amavis.service - LSB: Starts amavisd-new mailfilter
Loaded: loaded (/etc/init.d/amavis; generated; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2020-05-10 18:38:38 CEST; 4ms ag o
Process: 4194 ExecStart=/etc/init.d/amavis start (code=exited, status=1/FAILUR E)
May 10 18:38:38 Debian-911-stretch-64-minimal amavis[4194]: The value of va…en
May 10 18:38:38 Debian-911-stretch-64-minimal amavis[4194]: a fully qualifi…h.
May 10 18:38:38 Debian-911-stretch-64-minimal amavis[4194]: You must explic…me
May 10 18:38:38 Debian-911-stretch-64-minimal amavis[4194]: in /etc/amavis/…'s
May 10 18:38:38 Debian-911-stretch-64-minimal amavis[4194]: network name!
May 10 18:38:38 Debian-911-stretch-64-minimal amavis[4194]: (failed).
May 10 18:38:38 Debian-911-stretch-64-minimal systemd[1]: amavis.service: Con…=1
May 10 18:38:38 Debian-911-stretch-64-minimal systemd[1]: Failed to start LSB…r.
May 10 18:38:38 Debian-911-stretch-64-minimal systemd[1]: amavis.service: Uni…e.
May 10 18:38:38 Debian-911-stretch-64-minimal systemd[1]: amavis.service: Fai…'.
Hint: Some lines were ellipsized, use -l to show in full.
dpkg: error processing package amavisd-new (--configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
amavisd-new
E: Sub-process /usr/bin/dpkg returned an error code (1)
Du hast den Hostnamen des Servers nicht richtig gesetzt. Ohne richtigen Hostnamen startet amavis nicht.
Prüf den Hostnamen in /etc/hostname und /etc/hosts.
Bei korrektem Hostnamen gibt der befehl:
hostname
den kurzen hostnamen aus, also z.b. 'server1' und der befehl:
hostname -f
den vollständigen hostnamen, also z.B. 'server1.example.com'.
