ISPConfig 3.0.5.4 Patch 8 released
What's new in ISPConfig 3.0.5.4p8
This release contains a bugfix for an issue found in 3.0.5.4p7 that prevents data in System > Server config to be saved.
The "Reconfigure services" option can be answered with "no" on servers that run ISPConfig 3.0.5.4p5 - p7.
See changelog link below for a list of all changes that are included in this release.
Download
http://prdownloads.sourceforge.net/ispconfig/ISPConfig-3.0.5.4p8.tar.gz
Changelog
http://bugtracker.ispconfig.org/index.php?do=index&tasks=&project=3&due=86&status[]=
Known Issues:
BUG Reporting
Supported Linux Distributions
- Debian Etch (4.0) - Jessie (8.0) and Debian testing
- Ubuntu 7.10 - 15.04
- OpenSuSE 11 - 13.2
- CentOS 5.2 - 8
- Fedora 9 - 15
Installation
http://www.ispconfig.org/ispconfig-3/documentation/
Update
ispconfig_update.sh
Select "stable" as the update resource. The script will check if an updated version of ISPConfig 3 is available and then download the tar.gz and start the setup script.
http://www.faqforge.com/linux/controlpanels/ispconfig3/how-to-update-ispconfig-3/
Manual update instructions
cd /tmp
cd ispconfig3_install/install
php -q update.php
wotan2005
sieht etwas komisch aus:
There is a new Version of ISPConfig 3 available! This Version: 3.0.5.4p5 New Version : 3.0.5.4p7 See more... (<- ULR dann auf http://www.ispconfig.org/files/category/1-ispconfig/, wo dann der Patch: 3.0.5.4p6 angezeigt wird!)
Und doch eigentlich schon der Patch 8 da ist.
Danke für den Hinweis. Ich hatte die neue Version hoch geladen aber vergessen dass auf der Seite der Text auch nochmal drin steht.
