ISPConfig 3.0.4.2 released
ISPConfig 3.0.4.2 is available for download. This release is a bugfix release for ISPConfig 3.0.4.
For a detailed list of changes, please see the changelog section below.
*** New! The ISPConfig 3 manual is now available! ***
Version 1.3 for ISPConfig >= 3.0.4 (Date: 10/25/2011)
Author: Falko Timme <ft@falkotimme.com>
333 pages
The manual can be downloaded from these two links:
ISPConfig 3 Manual « ISPConfig – Hosting Control Panel
Version 1.3 Of The ISPConfig 3 Manual (Date: 10/25/2011) Available | HowtoForge - Linux Howtos and Tutorials
- Download
Download ISPConfig Hosting Control Panel from SourceForge.net
- Changelog
=]ISPConfig::ISPConfig 3: Tasklist
- Known Issues:
ISPConfig::All Projects: Tasklist
- BUG Reporting
- Supported Linux Distributions
- Debian Etch (4.0) - Squeeze (6.0)
- Ubuntu 7.10 - 11.10
- OpenSuSE 11 - 12.1
- CentOS 5.2 - 6.2
- Fedora 9 - 15
- Installation
Documentation « ISPConfig – Hosting Control Panel
- Update
ispconfig_update.sh
Select "stable" as the update resource. The script will check if an updated version of ISPConfig 3 is available and then download the tar.gz and start the setup script.
How to Update ISPConfig 3 « FAQforge
- Manual update instructions
cd /tmp
cd ispconfig3_install/install
php -q update.php
win_tho
Wenn auch etwas verspätet, auch hier keine Probleme. Nur das Update über die Weboberfläche hat nicht geklappt. Manuell lief aber alles wunderbar.
Das Update über die Weboberfläche wurde entfernt, steht in den release notes im bugtracker.
