Ich habe auf ein frisches Debian 10 Image per "Perfect Server Automated ISPConfig 3 Installation" die Installation durchgeführt.
Nun reagiert der Apache nicht auf Anfragen auf Port 443.
Wie kann ich dieses Problem beheben?
AH00548: NameVirtualHost has no effect and will be removed in the next release /etc/apache2/sites-enabled/000-ispconfig.vhost:7
VirtualHost configuration:
*:8080 isp.px01.xxxxx.de (/etc/apache2/sites-enabled/000-ispconfig.vhost:9)
*:80 is a NameVirtualHost
default server isp.px01.xxxxx.de (/etc/apache2/sites-enabled/000-default.conf:1)
port 80 namevhost isp.px01.xxxxx.de (/etc/apache2/sites-enabled/000-default.conf:1)
port 80 namevhost xxxxx.de (/etc/apache2/sites-enabled/100-xxxxx.de.vhost:7)
alias www.xxxxx.de
port 80 namevhost xxxx2.de (/etc/apache2/sites-enabled/100-xxxx2.de.vhost:7)
alias www.xxxx2.de
port 80 namevhost xxxx3.de (/etc/apache2/sites-enabled/100-xxxx3.de.vhost:7)
alias www.xxxx3.de
ServerRoot: "/etc/apache2"
Main DocumentRoot: "/var/www/html"
Main ErrorLog: "/var/log/apache2/error.log"
Mutex rewrite-map: using_defaults
Mutex ssl-stapling-refresh: using_defaults
Mutex authdigest-client: using_defaults
Mutex fcgid-proctbl: using_defaults
Mutex ssl-stapling: using_defaults
Mutex proxy: using_defaults
Mutex ssl-cache: using_defaults
Mutex default: dir="/var/run/apache2/" mechanism=default
Mutex fcgid-pipe: using_defaults
Mutex authdigest-opaque: using_defaults
Mutex watchdog-callback: using_defaults
PidFile: "/var/run/apache2/apache2.pid"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
Define: ENABLE_USR_LIB_CGI_BIN
User: name="www-data" id=33
Group: name="www-data" id=33
